Carbureted LSX forum - Fox Body guys....any engine bay pics?
streetknight2
02-15-2012, 09:56 PM
Just wondering, would like to see how some have done regulators, radiator hoses, water pump, etc.
Thanks
1994t/a
02-16-2012, 12:03 AM
LS1 water pump and alternator/bracket.LS1 camaro upper and lower radiator hoses.
http://i128.photobucket.com/albums/p163/lchs_38/110111202317.jpg
Before i got the radiator and hoses in place.Mounted the fuel pressure reg on the fire wall.
http://i128.photobucket.com/albums/p163/lchs_38/103011180610.jpg
johnyrrr
02-16-2012, 07:00 AM
Napa top hose and AutoZone bottom hose with All Star performance Radiator.
streetknight2
02-16-2012, 07:20 AM
which radiator did you use?
menchaca
02-16-2012, 07:23 AM
I used a stock f body radiator and stock f body hoses in my mustang.
streetknight2
02-16-2012, 08:50 AM
On alternator, did you convert to 1 wire or what?
xpndbl3
02-16-2012, 12:04 PM
Can't mount the regulator to the firewall per nhra rules if you plan on racing it ever it won't pass tech.
butler
02-16-2012, 12:37 PM
http://i455.photobucket.com/albums/qq272/lbroofing1/CIMG0682.jpgThis is with the 383 ls1. It got cleaned up when I put the lq9 in it.
richard david
02-16-2012, 03:01 PM
Has anyone been able to use stock hood with a victor Jr. And if so what oilpan and k member to use
S10xGN
02-16-2012, 07:41 PM
No offense, but it looks like a disgruntled assembly line worker took a 12 gauge loaded with #2 shot to work that day... WTF is with all those holes? Bracket mounts? More airflow for cooling? A place for all the oil to leak out of? <J/K> I know it's not on you!
bluecajun5.3
02-17-2012, 12:29 PM
truck l92 water pump, summit sfi balancer, truck radiator hoses, used radiator that came with the car as a roller. these are last Oct pics, has an alternator now with truck bracket.
http://i11.photobucket.com/albums/a162/cajungoose/th_SAM_0816.jpg (http://s11.photobucket.com/albums/a162/cajungoose/?action=view¤t=SAM_0816.jpg)
http://i11.photobucket.com/albums/a162/cajungoose/th_SAM_0820.jpg (http://s11.photobucket.com/albums/a162/cajungoose/?action=view¤t=SAM_0820.jpg)
my friend making a pass testing out his gopro...
http://i11.photobucket.com/albums/a162/cajungoose/th_GOPR0006.jpg (http://s11.photobucket.com/albums/a162/cajungoose/?action=view¤t=GOPR0006.mp4)
1994t/a
02-21-2012, 07:05 AM
Factory f-body radiator and fans.Also used ebay one wire alternator
streetknight2
02-23-2012, 09:19 AM
I can't use the f body accessories on the LQ4 can I? Thought I read some bolt holes were missing compared to the aluminum blocks.
Prorac1
02-23-2012, 09:28 AM
IIRC, you have to drill a hole and tap it on the driver side front of the block for the alternator bracket. It has been done. Eric L
xpndbl3
02-23-2012, 01:08 PM
just drill/tap a hole with the metric tap and it's all good, did it in about 30 minutes taking my time to drill straight into the block and level
Gray86hatch
02-23-2012, 03:15 PM
http://i1012.photobucket.com/albums/af247/gray86hatch/IMG_0485.jpg
LSmonster
02-23-2012, 08:34 PM
Old set-up before I went turbo
http://i581.photobucket.com/albums/ss259/Dragzilla/LS%20Coupe/Picture1783.jpg
Spoolin_Notch
02-29-2012, 09:05 PM
^ What Distributor set up is that? One of the best looking lsx foxbody engines bays I've seen!
LSmonster
03-01-2012, 10:37 AM
Thanks! It's a Jesel Belt drive distributor that is driven with a pulley and belt off the upper cam pulley... Which is a Jesel belt drive cam setup.
DMMizell
03-01-2012, 04:19 PM
the lil' ole 346
Spoolin_Notch
03-01-2012, 09:57 PM
Thanks LSmonster, What did that set up run you if you don't mind me asking? you can PM me if you don't want to post it on here.
Thanks!
