Pontiac Firebird 1967-2002 - 82 trans am build
Twin_Turbo
02-16-2012, 08:03 AM
Hey all,
I´m building an 82 Trans Am. I was initially going to install a large displacement SBC with Duggan heads but after finding out the heads are only 38cc chambers (they were so cool I had to have them) so the heads are now display pieces. I have since decided to stick an LS engine in it, at least an LS2 preferrably larger.
I traded my LT1 T56 for an LS one so that is taken care of. Currently using an LS1 long block for mockup so I can build the exhaust, the cooling system and other parts while I'm working out the details on the engine. I will most likely be using a front distributor setup and a carb spider intake, maybe with FI maybe carb.
The car itself has full tubular suspension, k member, bilstein shocks, all poly bushings, sumped tank, watts linkage, all new balljoints & steering system, 13" C5 front brakes, 14" rear.
Interior will be stock with most likely Recaro Sportster CS seats (I have a set of them in black alcantara)
Hoping to pick up some pointers here on the LS stuff. I already did a 2004GTO LS1/T56 swap in an 82 Corvette.
Some pics of the car:
http://www.vettemod.com/forum/imagehosting/24f1b2664ac71e.jpg
http://www.vettemod.com/forum/imagehosting/24f1b2664076bb.jpg
http://www.vettemod.com/forum/imagehosting/24f380a0937c80.jpg
http://www.vettemod.com/forum/imagehosting/24f380a08843b4.jpg
http://www.vettemod.com/forum/imagehosting/24f380a07cf2fe.jpg
http://www.vettemod.com/forum/imagehosting/24f380b2a194c5.jpg
http://www.vettemod.com/forum/imagehosting/24f38144a1ce7a.jpg
http://www.vettemod.com/forum/imagehosting/24f380b29662d8.jpg
I want it with gold wheels..maybe this
http://www.vettemod.com/forum/imagehosting/24f38dc1c38fb3.jpg
newschool72
02-16-2012, 03:08 PM
Might want to go to conversions/ hybrids forum to get more input. At least the firebird forum. Just trying to get you some response.
Twin_Turbo
02-16-2012, 03:36 PM
oops, I'm in the camaro forum LOL stupid me. I own a couple camaros...must be why I automatically went there. Let's see if someone can move this :D
tnx for the heads up
Twin_Turbo
02-17-2012, 10:13 AM
in the right section now :)
1965GP
02-17-2012, 12:11 PM
Car looks good- I like the black wheels.
tuske427
02-18-2012, 12:12 AM
Car looks great! Feel free to PM me if you have any LS swap questions for this car- I did the LS swap into my '84 T/A already.
I also prefer the black wheels.
Good luck with your build!
Twin_Turbo
02-18-2012, 01:34 PM
LS1 is in after grinding the moroso mounts.
http://www.vettemod.com/forum/imagehosting/24f3ffa1925fba.jpg
http://www.vettemod.com/forum/imagehosting/24f3ffa19d5f82.jpg
http://www.vettemod.com/forum/imagehosting/24f3ffa1a89888.jpg
http://www.vettemod.com/forum/imagehosting/24f3ffa1b45a4a.jpg
This is with 1" set back, plenty of room but the driveshaft is a little right so instead of 41.5" I'm getting a 41" one.
Ignore the quickly hacked/welded crossmember. It's non functional. I'm going to get some alston inboard SFCs and fabricate a mount off them. The way it's now I don't have exhaust clearance and I want it to run besides the tranny.
Rad fits too...well..almost LOL. Need to cut that large bulge off the steering box so I can get a hose end on the oil cooler part and I need to cut and angle the lower rad hose connection
http://www.vettemod.com/forum/imagehosting/24f3ffa1bec9cf.jpg
http://www.vettemod.com/forum/imagehosting/24f3ffa1ca25fc.jpg
I wanted to install the mcleod 4th gen master and didn't feel like taking the damned pedals out again. The 4th gen stud is SMALLER than the 3rd gen. Doing searches here in the past I could have sworn it was the other way around. Also, the high pedal issue..is it caused by the location? I doubt it, the location is very similar in relation to the shaft. I had a clevis that was the right ID but it's too wide, the stud on the 3rd gen pedals is too short... frustration!! I decided to take a short cut. I removed the rod end from the aftermarket master and fabricated my own clevis. There's plenty of sideways play because of the wave washer, no play af all in the direction of the pedal. Done, this will slip right on.
http://www.vettemod.com/forum/imagehosting/24f3ffa1d5729f.jpg
Twin_Turbo
02-25-2012, 09:48 AM
I decided the C5 conversion is pretty damn hideous...well...the caliper at least. It's got too much of a production look to it, not "pro touring" at all...so, I got some C6 Grand Sport calipers without logos (Kore3) thatI'll stick on. Might as well upgrade to 14" front brakes. I'd like to keep the 2pc rotors so I'm going to see if coleman or wilwood makes a rotor that bolts to the baer hub (if anyone knows the baer hub patter, 12 boltson ??? diameter)
Never liked that the C5calipers are remanuf. cores with dents and scratches.
This is going to look soooo much better
http://www.vettemod.com/forum/imagehosting/24f48f3889d909.jpg
Also bought some mac SFCs so I can start fabbing my trans mount off them when they come in.Wasgonna go with alstons but since I'm going to cut them up the macs were a better deal since they were significantly cheaper.
Twin_Turbo
05-21-2012, 04:59 AM
Got some more stuff done, I got my watts linkage installed and yippee a 4" exhaust tube clears, guess that solves the size I will run there :)
http://www.vettemod.com/forum/imagehosting/24f94ffcbcc117.jpg
http://www.vettemod.com/forum/imagehosting/24f7ce98f1ce39.jpg
The sway bar wouldn't clear so I fabbed some spacers, good thing I welded the sway bar saddles to the axle, I can't get longer u clamps anywhere
http://www.vettemod.com/forum/imagehosting/24f94ffcb0e653.jpg
Welded some standoffs to the radiator and mounted it
http://www.vettemod.com/forum/imagehosting/24f94ffcc7d73c.jpg
rear calipers, they are slightly used returns because of flaking paint (will repaint them anyway)
http://www.vettemod.com/forum/imagehosting/24f94ffcd2dd35.jpg
Rear brakes will end up something like this
http://www.vettemod.com/forum/imagehosting/24f9500dbdeb90.jpg
http://www.vettemod.com/forum/imagehosting/24f9500db483c3.jpg
Fabbing up trans mount/tq arm mount off SFCs
I will use some tube connectors like from ballistic fab or something alike to make the center section removable
http://www.vettemod.com/forum/imagehosting/24fa2ae3890c08.jpg
http://www.vettemod.com/forum/imagehosting/24fa2ae39508c7.jpg
driveshaft loop (and the driveshaft I scored on here :) ) The zip ties are my bubba way of holding the driveshaft somewhat in place, I don't have a 1350 yoke yet, got one on order from summit. All I had was a 1310 from a TH350 so that has to do for mockup.
http://www.vettemod.com/forum/imagehosting/24fa568f3e0674.jpg
Next problem is getting a big exhaust fit under here, biggest obstacle in getting a Y system is the trans mount and the TQ arm mount, so nothing left to do but move the tranny mount. I fabbed up my own little bushing mount and relocation bracket (will add gusset), the bar on the left of the pic will go, it's there to keep the tranny up for mockup only. The exhaust will fit nicely along the tailstock of the trans there and meet up with the other side into a Y mergo to a 4" pipe.
http://www.vettemod.com/forum/imagehosting/24fa6b55a3eef8.jpg
Zombiesoldier
05-21-2012, 04:15 PM
Looks like a great build!!!
Ozz1967
07-13-2012, 01:22 PM
Nice looking car man. How did you get the AN fittings on your radiator? I'd love to do that to the aluminum radiator I'm running in my 84. Also, do you have AN connectors on your water pump?
ramairetransam
07-13-2012, 01:50 PM
sweet ride
BANDITCAR
07-13-2012, 10:58 PM
Gorgeous 3rd Gen...loving this build!
Twin_Turbo
07-19-2012, 05:14 PM
It's all going slow, waiting on the container with parts. Only progress I made is buying a short block and LS7 heads for it, the short block is a LSX 495. Also got a front distributor drive cover for it. I will be running a carb on it. Don't want to have all the wiring junk from a FI system on it anymore like on my Camaro. It's a spaghetti of wiring, I hate it.
The rad came like that with the -20 AN bungs. If not, it's simply a matter of welding on some bungs. I will run a -20 AN hose. This is what I have on my camaro also. I detest hose clamps.
http://www.vettemod.com/forum/imagehosting/24f970fe3e6eb6.jpg
Similar setup, MiniRam 355 where I modified the thermostat housing, simply a -20 bung welded on
http://www.vettemod.com/forum/imagehosting/24fff4e1abfc84.jpg
Modified radiator (original hose connection does not fit w/ D1SC)
http://www.vettemod.com/forum/imagehosting/24f5d131a6764d.jpg
Twin_Turbo
07-21-2012, 03:09 PM
Got my metco arms on. Seriously nice stuff!!
http://www.vettemod.com/forum/imagehosting/2500b066e75816.jpg
http://www.vettemod.com/forum/imagehosting/2500b066ecab55.jpg
Also, put my fab yer own headers project on hold, no use using the mockup block for that gives that the actual engine is a tall deck.
Anyone know what the shallowest wet sump pan is for the front section? Engine is a little low in ther, have clearance probs w/ the center link. I don't think the corvette bat wing pan would fit.
Twin_Turbo
07-30-2012, 07:32 AM
Got the inner SFCs/trans mount and otherstuff combo done. All welded up, ready for the powdercoater to redo it. These parts like the SFCs all come with junk coating, simply coated over the mill scale and everything and no primer coat. My coater blasts, primers and top coats. Much much more durable that this junk. I installed the same type of SFCs under my gray iroc and the coating is flaking off and there's surface rust under it.
http://www.vettemod.com/forum/imagehosting/250159c0aba48c.jpg
My buddy bought some wheels for his silver 83 TA. Couldn't pass it fitting them. They may look good on there in gold but I fear they do not offer enough caliper clearance. Mixed feelings on them though
http://www.vettemod.com/forum/imagehosting/250159c0b229f2.jpg
http://www.vettemod.com/forum/imagehosting/250159c0b72797.jpg
Twin_Turbo
01-18-2013, 07:34 PM
Woohoo :D
Major step ahead! Soon I can start building the rest of this engine. Still got tons of stuff I need though and headers to fabricate
http://www.vettemod.com/forum/imagehosting/250f9f76b7b3d8.jpg
http://www.vettemod.com/forum/imagehosting/250f9f76bd83e8.jpg
http://www.vettemod.com/forum/imagehosting/250f9f76c33f0f.jpg
89ROC-Z
01-18-2013, 10:11 PM
Holy nice build going on here! 495" tall deck?
Twin_Turbo
01-19-2013, 03:34 AM
Yes :D
TypeSL2
01-20-2013, 10:28 AM
Looking sweet man. Can't wait to see the finished product. I dig the BBS Reps. They look pretty good on that car. Kinda old schoolish.
James
Twin_Turbo
01-20-2013, 12:29 PM
yeah but my C6Z06 calipers don't fit behind them so...they are a no go.
Blackpanther99
01-20-2013, 03:03 PM
Holy cow, great progress!
Twin_Turbo
01-26-2013, 04:36 PM
A little fuel pump w/ pre and post filter. -10 fuel lines. I may end up running the pressure regulator in the back and using a dead headed line to the carb. Don't feel like running 2 -10 lines to the front. I can run 1 through my pass side SFC
http://www.vettemod.com/forum/imagehosting/2510457e2e029c.jpg
http://www.vettemod.com/forum/imagehosting/2510457e36752f.jpg
Bandit 43
01-27-2013, 08:44 AM
Great build, keep up the good work. Sure I speak for most when I say, love the updates with all the pics.
Twin_Turbo
03-30-2013, 12:30 PM
another nice piece came in, WCCH ported tall deck LS7 carb manifold. I decided to use this instead of the mast in hopes of keeping things under the stock hood....fingers crossed
http://www.vettemod.com/forum/imagehosting/25151c92c01e8f.jpg
http://www.vettemod.com/forum/imagehosting/25151c92c43d2a.jpg
http://www.vettemod.com/forum/imagehosting/25151c92c8b986.jpg
http://www.vettemod.com/forum/imagehosting/25151c92ba5c03.jpg
well crap, as I had feared...it won't fit under the hood :( so there goes the nice power bulge hood, time for something aftermarket then
http://www.vettemod.com/forum/imagehosting/25157116b503ef.jpg
http://www.vettemod.com/forum/imagehosting/25157116b91b22.jpg
it would probably clear without an air cleaner
http://www.vettemod.com/forum/imagehosting/25157116b0e966.jpg
Furious1
03-30-2013, 12:40 PM
Love it. Keep the black concaves...they look sick.
Twin_Turbo
03-30-2013, 04:45 PM
can't...they are on one of my other cars
http://www.vettemod.com/forum/imagehosting/2502fb4cdbb984.jpg
