Dyno Guesses & Bench Racing Forum - What should I run in the 1/8?
Lovemy77camaro
02-17-2012, 07:54 AM
I have a 00 trans am m6 car. I've done 4.10 gears with moser axles and ta cover. Also I have done slp lid, bbk headers, i ported the tb, ported the MAF ends, frost tune, free ram air mod, tb bypass, and MSD wires. What should I run and maybe what kind of power should I be making? Also any other good inexpressive mods I'm missing?
1Bad97WS-6
02-17-2012, 01:47 PM
I would say you should run 8.0s-8.20s.. weight reduction is your friend..
JWStevens
02-17-2012, 02:02 PM
About that if I had to guess. What did it run stock?
Lovemy77camaro
02-17-2012, 03:36 PM
I haven't run it stock, I've only had it two months. I forgot to mention it has 160k on it :(
JWStevens
02-17-2012, 04:21 PM
I wouldn't worry about that too much but that's just me and I'm usually wrong. It'll do good, don't worry. Good luck!
Xtreme864
02-18-2012, 08:23 AM
Seems like you've got pretty similar mods to mine but mines an A4. Mine ran an 8.2x@84 mph in 95 degree weather and tapping the limiter on a slippy 2-3 shift. So depending on how good you can drive it without breaking it, you should be low 8's all day long. With a possible 7.9 on a well prepped track with a perfect DA. Now that my tranny's fixed, I hope to see 7's. On street tires :) cut a 1.9 60' on 275 nitto streets when I ran that time.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
