Drag Racing Tech - M6 Nitrous Gear Qs
223HAWK
02-17-2012, 09:03 PM
Basic Heads Cam car, Makes about around 450 to the tire N/A. I cant remember dyno numbers off the top of my head. Anyway..that has been my set up for last season with a 100 shot. Car was full weight. I ran a 4:10 with a 28in Tire. Went 10.6s-10.7s all day @ 125-126. Shifting about 6500. This winter Iv done some weight reduction(maybe 125 lbs) and wanted to spray more (150-200 range) and swap gears to 4:56s. Also at this time doing rod bolts, bearings. I figured safely I could turn the car 7200 and stil be able to mph around 134-135. My goal is to be low tens knocking on 9s with some work. Am I wrong in my thinking? Would 4:10s be better or even 4:30s be better?
67RSCamaroVette
02-18-2012, 12:24 AM
I'd choose the slightly taller gear to take advantage of that bigger shot's torque.
John Deere racer
02-18-2012, 11:45 AM
4.30 would b your better choice
JeffT
02-19-2012, 02:16 PM
Leave the 4.10's and jet up.
moge11
02-20-2012, 01:14 AM
yup :D
BlackScreaminMachine
02-20-2012, 01:14 PM
Getting the car to leave good is the part you need to worry about. Aggressive suspension and most likely a de either a progressive kit or 2-step will be key. I would do everything else but gears. See how it runs. I.e. test n tune.
Then see if gearing is required.
Fbodyjunkie06
02-22-2012, 04:29 PM
I told you in the other thread, nitrous makes torque.
Taller gearing takes advantage of torque. You'd be fine with your 28's, 4.10's and pill that bitch up.
223HAWK
02-23-2012, 07:47 AM
Changed my mind lol Ganna go 4:30s and hit it a little more
John Deere racer
02-23-2012, 08:40 AM
Ull b fine
I went 131mph with a 4.30 and cam only 150shot
And wasn't turning motor 7k like it lOoks u are
Good luck
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
