What is it Worth? - whats it worth 98 ws6 procharged
View Full Version : whats it worth 98 ws6 procharged
jbowles17
02-17-2012, 09:13 PM
Im looking at buying a 1998 trans am. 72k on body 5k on build needs bigger fuel lines and a tune. car has 6.0 iron block all forged internals 90 mm tb and intake. ported heads. d1sc procharger 14psi with a little belt slip. 400 turbo trans with reverse valve body n 4000 stall. ford 9" rear end with 3:70 gears and full spool. 315-50/15 on rear skinnies up front. the car was built a few years ago n was never finished and just sat. clean car. ttops. frame conectors. hes asking 14k
projectX
02-17-2012, 09:24 PM
Not sure but sounds sick - hell I'd buy it - HA
jbowles17
02-17-2012, 09:36 PM
Right I'm just trying figure if its worth it. he has reciepts for 20k$ that he put in the car after he bought it.
projectX
02-18-2012, 10:18 AM
Well if your taking out a loan for it you wont get what its worth unfortunately. I would say 13k sounds fair.
jbowles17
02-18-2012, 10:47 AM
im not doin a loan. im not finding very many ws6 with sc for under 15k. and this one has alot more then sc for ungrades.
projectX
02-18-2012, 04:46 PM
Yeah, I'd say it's a great deal.
jbowles17
02-18-2012, 05:03 PM
heres a few pics that i took of it
ramairetransam
02-18-2012, 06:41 PM
buy it , great price , built trans , built rear , strong engine , procharger , totally do it.
TonyGXP
02-18-2012, 11:32 PM
5k miles on the motor? the one starving for fuel while under boost lol.. how do you think those miles were traveled lol. waaaay overpriced. When buying a modded car go by the book without mods then add about 20% of what he says he spent (and looks right to you). when we mod our cars, we don't do it thinking resale will be higher, so why should you be the sucker? you know how limited the market is for "that car"?? there's a sucker born every minute for sure, remember that before you offer him anything close to that.
lol needs bigger fuel lines, that thing is probably one tank of NOT 100 octane away or low meth away from disaster. how long he been running that boosted fuel starved thing for? forged motors blow up too man.
$11.5k MAX if it were me. he says no, wasn't meant to be move on.
Snake_Skinner
02-19-2012, 01:29 AM
Worth every bit of 14K if everything's legit and it runs good, I'd buy it before someone else does.
jbowles17
02-19-2012, 09:47 AM
The methanol injection isn't hooked up. I've know guy the whole time he has had the car and he does n't beaton it judt daily drives it gets on it every once in a while. The car doesn't run lien until u hold it wide open for a while. And what it does is stall out when it runs lien cuz it runs outta fuel, and that only has happened once. Car runs 14lbs of boost, so requires more fuel than the stock lines allow to go through. He's never made a pass on this set up. It's mostly a cruise around car n quick spirts here n there. He said it has no timing right now n a 6k rev limiter for safty so don't blow up. Couodnt tune with out new lineage
jbowles17
02-19-2012, 09:59 AM
Car has good fuel pressure n oil pressure. Starts good. Just some times don't wanna idle n stalls. And u can't go wot through all gears cause lines other wise seems good dont get hot n wide band is in clear unless u hold throttle for a long time then leins out.
jbowles17
02-22-2012, 07:25 AM
I offered him 12 he said no. U guy think worth more. There's a lot in this car compared to other sc ws6 on here. Ive considered doin my own but I'd have 30k in it
