Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
FS: LS1 V8 240 Complete Swap, EVERYTHING needed minus motor set, SUPER CHEAP!!! Pics
Old 02-18-2012, 02:45 AM
D.Jones's Avatar
Default FS: LS1 V8 240 Complete Swap, EVERYTHING needed minus motor set, SUPER CHEAP!!! Pics
Category: Steering & Suspension
Price: $2500
Location (State): FL
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Going a different route, so selling absolutely everything you need to swap a ls1 or any lsx motor into a 240sx. All of this came out of my personal running ls1 240 so this is a complete swap kit, nothing else needed but a motor, tranny, and pcm... that's it! No guessing or buying random parts here and there and piecing together different parts that may not work with each other. Also, everything is basically brand new as I only finished the swap about two months ago and never really got to drive it due to a bad clutch that came with my tranny :/
What's all included:
- modified front cross member to clear GTO oil pan
- aluminum corvette motor mount brackets
- Energy Suspension polyurethane motor mount bushings
- Energy Suspension Polyurethane tranny mount bushings
- tranny bracket
- GTO oil pan (needed to clear cross member)
- GTO oil pickup
- Ceramic coated custom headers with welded v-band flanges
- full converted wire harness, clean and routes like factory
- beefy 3.5" aluminum drive shaft ( has a mark from rubbing a v-band clamp on my exhaust, check pic)
- custom aluminum fan shroud
- brand new dual ls1 fbody electric fans, flows 10,000 cfm vs 2,500 cfm with flex-a-lite fans
- stainless steel braided high pressure power steering line
- AN fittings for high pressure power steering line
- return power steering line
- stainless steel v-band clamps for headers
- GM MLS exhaust manifold gaskets
- upper and lower radiator hoses fitted for ls1 when using ka radiator
- temp. sensor adapter with fitting and hose
- all bolts and hardware
- I may be forgetting a few things, but those are the main parts
Selling everything for only $3000 shipped AND PayPal'd to anywhere within the lower 48 states. I also have a full 304 stainless steel y-pipe that bolts right up to the headers with the v-band clamps I can include for extra.
Pics:
Old 02-22-2012, 11:34 PM
D.Jones's Avatar
have recieved a lot of pm's but everything is still for sale.
please bump if viewed, thanks Tech
Old 02-24-2012, 10:30 PM
D.Jones's Avatar
Everything is currently pending, thanks for the interest.
Quick Reply: FS: LS1 V8 240 Complete Swap, EVERYTHING needed minus motor set, SUPER CHEAP!!! Pics
