Belt slip on Maggie
Belt slip on Maggie
Im hoping to hear from some Maggie people that have had this issue
Is this curable with a different brand belt ? I can't tell which brand belt I have (it came with the blower stock).
After waiting to get the tune finalized because of clutch slip issues .... Now I have belt slip issues. We just installed a twin disc clutch to hold the torque and now the highly anticipated Dyno day .... Only to find that my HP & TQ take a dive at exactly 5800 rpm. On the street I can watch my boost gauge drop from 7lbs down to a fluttering 4 -5 lbs or so.
I would like to hear that a magic belt will fix the problem. Rather than a change to an 8 rib system etc..
Thanks in advance for the help.
FYI: I have a 2.9" pulley @ 7 lbs.
11 sec. Truck Mod
Adding a set of dayco 101mm idler pullies will help belt wrap.
I also run a Dayco belt, works great, i have a 2.6 pulley and IW overdriven balancer, I do get a little belt slip at the very top end but with what the truck runs/makes im happy
Also do you have an HD tensioner? Thats a must have.
How tight is too tight??
After changing the belt to a smaller gator back belt ... The same slip was still happening. I then installed a manual tension adjuster ( not spring loaded). It is fixing the problem, I still had belt slip and the tighter I made the belt the higher up n the rpm range the slip would occur. I have titened the belt leaving a little more play left in the tension. In other words I still have about a 1/4 of an inch left before it feels like the is no give at all.
How much is too tight.
I'm concerned with wear and tear on the other components bearings ie: power steering & alternator.
Ps: boost still drops off around 6k but not as drastic as before.
