Another Pushrod/Preload Question
Old 02-18-2012, 05:38 PM
marksboy7's Avatar
Default Another Pushrod/Preload Question
Ok first off, probably a dumb question but I'm curious, do I have to soak my lifters in oil before I install them and take a measurement for pushrods? Ok I have the Morel link-bar lifters and I used a stock pushrod (7.400) to measure for my new pushrods. After finding zero lash it took me 1 turn to torque to 22ft lbs. I know 1 turn equals .047 of preload. Do I add that to the pushrod length to get the new pushrods of 7.450? What is the correct size that I need?
Old 02-18-2012, 05:47 PM
ZeeOSix's Avatar
If one turn gives you ~0.047" pre-load with 7.400" pushrods, then you would want longer pushrods for more pre-load, and shorter pushrods for less pre-load.
For instance, if you wanted ~0.060" pre-load you'd want 7.415" pushrods. If you wanted ~0.070" pre-load, then you'd want 7.425" pushrods.
Old 02-18-2012, 07:30 PM
marksboy7's Avatar
Ok so I guess I need to know how much preload to run? Is there a nominal amount for the Morel lifters or a certain amount I need to run?
Old 02-18-2012, 08:35 PM
Darkman's Avatar
The Morels use a pre-load of 0.030" to 0.050". I used 0.050" on mine and have very little valve train noise.
Old 02-19-2012, 07:28 AM
vettenuts's Avatar
Same here. You need to buy an adjustable pushrod and make an accurate measurement with these lifters since you have a 0.020" band to work with. I also spoke with someone at Morel before installing mine, he suggested putting the lifters in oil and rotating the wheel to break the grease up a bit before installing. I also coated the cam lobes with Redline Assembly Lube along with the pushrod tips and valve stem.
Old 02-19-2012, 09:07 AM
marksboy7's Avatar
Alright I've got an adjustable pushrod, I'll just have to make a measurement with it and see what I get. Thanks so far for the advice.
Old 02-19-2012, 10:17 AM
bww3588's Avatar
Do not soak the lifters, If you do, it will fill up totally with oil and you Will never get an accurate preload measurement.
Old 02-19-2012, 03:11 PM
marksboy7's Avatar
Ok don't soak lifters, check. Alright I measured with the adjustable pushrod and I came up with 7.3125. I'm using a comp cams checker and it took 10 1/4 turns. So now that I've got that do I just add the desired preload to it?
Old 02-19-2012, 06:52 PM
ZeeOSix's Avatar
Add your desired lifter pre-load to your zero lash lenght measurement of 7.3125".
If you want 0.050" pre-load, then: 7.3125" + 0.050" = 7.363".
You can either buy pushrods as close as possible to the required lenght, or have some custom made.
Keep in mind that the Comp Cams pushrod checking tool measures in "gauge lenght".
Attached Thumbnails Another Pushrod/Preload Question-pushrod-measurements.jpg
Old 02-19-2012, 11:52 PM
technicalninja's Avatar
My first thought was "damn he's close with stock length pushrods".
As it only took 1 turn to torque you are going to have little less pre-load than you think as approx 1/3 of the final turn is what applies the locking torque to the bolt (it doesn't push the rocker/pushrod down farther).
As long as you were accurate in finding zero lash with this mock up you were close to perfect with the 7.4s.
I was expecting you to come up with a reading around 7.370 this way. I'd recheck closely if you really did the first test correctly. I'm **** so I would check all 8 but I suggest checking more than 1 and get an "average" across the engine.
If the checking tool turns out to be accurate and you are really seeing 7.3125 I'd purchase 7.350 length pushrods which should give you a pre-load of .037.
Old 02-20-2012, 11:30 AM
vettenuts's Avatar
The other option is custom length, which will deliver quick from someone like Terry Manton at Manton Pushrods. You could also try Trend, I got custom length fully machined double taper pushrods within a week.
Old 02-20-2012, 11:59 AM
02blackbeauty19's Avatar
I don't mean to hijack, but since it seems the OP's questions have been answered and I don't want to clutter up the site, I'll ask here.
I have the Comp pushrod length checker and proceeded to measure Cyl. 1. It took 9.5 turns to get where I was comfortable with zero lash. The intake valve I couldn't really move at this length, but the exhaust valve would lift very little (without a tick, tick sound). So, at that many turns, I got 7.275" + what ever preload I choose. I think I want to shoot for 0.05".
I wanted to double check so I moved to Cyl. 6. On these two, I got 10.5 turns to zero lash. That game me a length of 7.325" + desired preload.
I had no real way of measuring TDC other than my eyeball, so I'm guessing that's why the pushrod measurements are equal lengths apart, in different directions? Am I correct in assuming that?
I know the Comp tool is measured in gauge length, so how would I equate that into my measurements?
Right now, It looks like I'll have to order some 7.350" pushrods with my 0.05" preload. I read that this is a great preload for a quiet valvetrain, but it doesn't seem to be well understood on the interwebz. I have a set of Texas-Speed 7.400 pushrods, but I'm afraid they will be too long.
Old 02-20-2012, 01:25 PM
marksboy7's Avatar
Ok measured #6 and got 7.3125" just like #1. Does the gauge length mean I need to add anything to my total length? If not it looks like I could run 7.350" and have aprox. .040" of preload.
Old 02-21-2012, 02:58 PM
marksboy7's Avatar
Looks like 7.350" it is, unless anyone sees something I did wrong.
Old 02-21-2012, 03:37 PM
vettenuts's Avatar
Not sure I follow everything you did, but in a nutshell the piston should be at TDC on the firing stroke otherwise the lobes of the cams may not be positioned so that the lifter is on the base circle. If your #1 was at TDC on firing stroke than no other cylinder has its cam lobes positioned so that both lifters are on the base circle.
Old 02-21-2012, 03:39 PM
vettenuts's Avatar
By counting turns you are actually measuring to gauge length. This is the length your order for most pushrods. Trend uses this measurement and as a result so does Comp since Trend makes their pushrods. Manton on the other hand uses overall length and you need a caliper to measure your adjustable pushrod to get this measurement. Hope this make sense.
Old 02-21-2012, 07:23 PM
ZeeOSix's Avatar
To add info ... Manton uses "flat-to-flat" distance as the overall length.
Another way to get the "flat-to-flat" length from the gauge length measurement is to add 0.015" to the gauge length. See attachment in Post #9.
For instance, 7.385" gauge length would equal 7.400" flat-to-flat length.
Old 02-21-2012, 07:27 PM
ZeeOSix's Avatar
I thought the Shane method was verified by using a dial indicator on the rocker arm when he came up with the "1 turn = 0.047" of pre-load".
Old 02-21-2012, 08:31 PM
marksboy7's Avatar
Thanks for all the info and help everybody. So I got 7.3125" measured + 0.050" preload + 0.015" gauge length = 7.3775" Looks like I should go with a 7.375" pushrod and should be just fine.
Old 02-22-2012, 03:22 AM
ZeeOSix's Avatar
It depends if you buy pushrods that are specified in gauge length (like Comp Cams) or by total length flat-to-flat (like Manton).
If you use pushrods specified by the gauge length, then you would need 7.3125 + 0.050 = 7.3625 since you used the Comp Cams length checking tool, which gives you a gauge length measurement.
If you use pushrods specified by the flat-to-flat lenght, then you would need pushrods that were 7.3775 from flat-to-flat as you showed above.
Quick Reply: Another Pushrod/Preload Question
