Dynamometer Results & Comparisons - G6x3,AFR,stock 346
John Deere racer
02-18-2012, 06:25 PM
474rwhp 417rwtq
70cc 10.1 comp. 30 degrees timing
M6 4.56 gear m9 rear 28in Hoosier DR
McLeod street twin
FTP 104 lid
90mm tb
Fast 102 intake
AFR 225 70cc, 10.1 compression , 30 degrees of timing
G6x3
UDP
ARH 1 7/8
3.5in y pipe w/ magnaflow muffler dumped
Stock short block with arp rod bolts
98blueSScamaro
02-18-2012, 07:14 PM
474rwhp 417rwtq
McLeod street twin
FTP 104 lid
90mm tb
Fast 102 intake
AFR 225
G6x3
UDP
ARH 1 7/8
Jason still some fine tuning that needs to be done. and what fuel did you have in it??? what are your tires set to for psi. slicks kill your numbers..
Rob
John Deere racer
02-18-2012, 07:41 PM
Rob
Hi
Rob
Yeah I was hope n for a lil more hp
93oct
Don't know how much air psi was in tires
98blueSScamaro
02-18-2012, 08:10 PM
after reading your email everythings all clear. car will make alot of power and we need to try diff fuels. dont worry bud it should be close to 500hp.
Rob
Fbodyjunkie06
02-18-2012, 08:24 PM
Strong numbers.
John Deere racer
02-18-2012, 08:28 PM
Rob
I have a 55 gallon drum of 104 unleaded
I'll b running ... Should had it in car at time of tuning
John Deere racer
02-18-2012, 08:37 PM
Dyno numbers don't always mean much I guess
Yrs ago with a g5x2 I made 390rwhp and went 11.20@122 full weight
So I'm sure this combo will b goo for low 10s
John Deere racer
02-19-2012, 02:33 PM
Strong numbers.
Thanks
John Deere racer
02-20-2012, 05:39 PM
Got the car today
Runs very well
I have 2 vids but have no clue how to post them
98blueSScamaro
02-21-2012, 12:35 AM
i will post the vids tomorrow for you bro.
LS1Aggie09
02-21-2012, 02:45 AM
sounds like a great setup! what are the specs on g6x3 and about how much did the entire setup run you?
John Deere racer
02-21-2012, 07:18 AM
Don't know the specs
And never kept track on cost
Sorry
zz4camaro1980
02-21-2012, 07:47 AM
Rob
Am I missing something?...Why run 104 when you only have 10:1 Compression?
John Deere racer
02-21-2012, 07:59 AM
Not sure?
What are u suppose to Miss?
I'm sure 104 will run better than 93 when I'm beating on it
Lol maybe I like the smell
Gordon0652
02-21-2012, 08:08 AM
474rwhp 417rwtq
McLeod street twin
FTP 104 lid
90mm tb
Fast 102 intake
G6x3
UDP
ARH 1 7/8
That's badass, up that compression and maybe a 102TB and be 490 at the tire? Good numbers with that rear!
zz4camaro1980
Not sure?
My car runs fine on 93 and I have 11.2:1 Comp. Im sure there is some power to be gained (when properly tuned for 104) but it just seems like overkill.
were/are you I8AFORD from the MFBA?
John Deere racer
02-21-2012, 09:13 AM
Yep
I remember u
John Deere racer
02-21-2012, 09:16 AM
I run it in all 3. My vehicles at the track
I like the extra precaution of not worry bout spark knock
As now adays u don't what kinda condition gas is in
I have a 500 gallon tank of 93oct at my house from country mark
Damn stuff runs better than gas at stations
John Deere racer
02-21-2012, 09:21 AM
Thanks
I wanted to is a 102tb
But my 2 tuners I deal with told me it wouldn't help
So I do as they say ... Lol
zz4camaro1980
02-21-2012, 09:29 AM
Rob
gotcha, 98blueSS comment threw me off. I thought he was implying a 25 rwhp jump going from 93->104.
Either way, nice numbers! Let us know when you get to the track. Any susp. work? 11.2@122 is moving for 390rwhp, you definetly have that thing dialed in!
John Deere racer
02-21-2012, 09:47 AM
Thanks
11.22 was on a old car from 10yrs ago. When. G5x2 came out
It didn't have much suspension work
The car just had built
K member A arms. Afco Drag bar
M9 tq arm
98blueSScamaro
02-21-2012, 03:32 PM
setup has more left in it with more compression. I would like to see at least 11.5.1 and good gas. so it will give you room if you want to use the heads on a bigger cube build.
98blueSScamaro
02-21-2012, 08:26 PM
Idle Vid of this monster
http://www.youtube.com/watch?v=_735ULlRODc
98blueSScamaro
02-21-2012, 08:27 PM
Showing off how good of a driver he is....
http://www.youtube.com/watch?v=jIUfn4Ohc3k
98blueSScamaro
02-21-2012, 08:28 PM
More good driving....
http://www.youtube.com/watch?v=JMW_ZM9hwe0
Gordon0652
02-22-2012, 05:13 PM
Thanks
Thinking about it, it wouldn't because the FAST102 is built for bigger cubic inch engines anyways. Like the sound of the beast!
litle88
02-22-2012, 05:45 PM
Does sound nice!
Rob Mill those heads bud!!!
John Deere racer
02-22-2012, 06:35 PM
Thanks guys
Yeah milling would pic up A few hp
tunedup
02-22-2012, 07:07 PM
Nice setup and driving. What slave/master combo are you running with that street twin?
John Deere racer
02-22-2012, 07:47 PM
New Gm slave /Tick performance master
275/60 hosier dr
Not doing bad for 30lbs in tires ... Just checked them
Thanks for compliments guys
Tony Mamo @ AFR
02-23-2012, 01:47 PM
X2
Low static compression and a big cam really dont play well together.....the fact you made the power you did is actually impressive.
Your cylinder pressure and DCR is suuuuper low with this set-up. You could have easily ran 11.5 with pump gas and not experienced any knock whatsoever with even a so-so tune (wouldn't have to be deadly spot on). Both torque and HP would have been up considrably.....compression really helps larger cammed combo's because the overlap and late valve events kill the cylinder pressure and the name of the game is to try and build as much cylinder pressure as possible.....thats whats creating all the twisting force in the first place.
A 102 TB is worth another 5 ponies on this combo btw.....not the end of the world but it all adds up. More compression (especially with a tight quench) and a larger TB would have put the torque over 430 and close to 500 to the ground on power.
Car sounds great btw....love the exhaust note!
More in it if your up for going in and wrenching again!
Enjoy the new combo
:chug:
-Tony
PS....Would like to see the dyno curve.....any way to post that up?
John Deere racer
02-23-2012, 01:50 PM
X2
Enjoy the new combo
:chug:
-Tony
Thanks for info
I may get heads milled and 102tb
Mike Norris has the graph
I'll check with him
Tony Mamo @ AFR
02-23-2012, 02:04 PM
Thanks for info
I'll check with him
Wow....didn't realize this was on Norris's dyno (the Humbler.....LOL). Its actually quite stingy.....his STD numbers are lower than most dyno's SAE figures. In fact Im pretty sure he runs most of his cars on that correction factor now because its closer to a typical Dynojet number.
Anyway....if you take the car apart to mill the heads consider sending the 102 off to me to get ported....I would suspect we could clear the 500 mark with the intake, compression, and TB change. the entire curve would be fatter and it would come up on the cam much faster with a a little more cylinder pressure from the higher CR figures.
-Tony
John Deere racer
02-23-2012, 02:47 PM
-Tony
Mike actually did say his dyno reads low
U will getting my intake to port
Thanks again
NHRAFORMULA00
02-23-2012, 06:04 PM
I am glad Tony posted on your compression,or lack of it,as i was going to ask you the same ? why so little. Chris has fly cutting tools if you need them,also his motor is just over 12/1 and he adds a spash of 100 no lead to it with no KR.
John Deere racer
02-23-2012, 06:12 PM
Hi Elmer
It's fly cut
I should ask more on heads
I dOnt know that much bout that stuff
I just want hp and will drive the shot out of it
I called Louis G told him send me some heads for a 2002 that's bout as far as it went
The cam was for my 2011... Then I bought a 2002 and kept the 11 bolt ons and just used the cam for that car,,, then just ordered heads and intake for the 2002
I'm sure we'll get it tweaked a bit more
Louis
02-23-2012, 10:49 PM
I didn't want Jason to spend money on heads twice. Yep, the compression is low, but they will fit golden on his 427 or 415 like his last car. The 346 won't last long, so I didn't feel right selling him heads twice. It'll either give up the ghost, or Jason will upgrade. Either way, he is going to wring it out!
Tony, this is the car we spoke about regarding 225s and small bore, and what gasket to use.
2 more points of compression will help a ton. Just put a 4" crank in it!
John Deere racer
02-24-2012, 07:17 AM
Good point Louis
I do remember u saying you where going to get me heads that would go toward my next build
Thanks for take n care of me
chrs1313
02-24-2012, 12:57 PM
Good point Louis
Take the heads off and bump that compression... you can always use the same heads on a bigger motor, i.e. (you are going to buy pistons anyways so just get dished instead of flat or domed)
.040 gasket will bump you ~.4 alone...
Also your tuner is right if you are running a 98-104mm FTP lid the 102 TB will not help much at all...The restriction in the intake track is the lid...It flows similiar to around a 85mm bellmouth opening...and yes there is no difffernce between the 104mm and the 98mm (they both neck down the same)...that is why i made a custom 4" bellmouth lid ;)...I picked up 6rwhp from just a lid swap and that was with a 92mm tb for both runs.
Louis
02-24-2012, 05:38 PM
Why even give the 346 the time of day? Flattop will make the most power, no reason to run a dish on an NA just to get a number on a 346. I'll send him AFR 210s if he wants to swap. There's no point.
John Deere racer
02-26-2012, 08:07 PM
Hey Louis
Send me a 427 short block!!
mike c.
02-27-2012, 11:59 AM
Hey louis,send me a 434ci with the best afr heads you have. in return,i'll go to every speed shop around and put your shops logo and phone number over theirs...:D
John Deere racer
02-27-2012, 04:42 PM
http://i1154.photobucket.com/albums/p540/i8aford/0b43f3b0.jpg
John Deere racer
http://i1154.photobucket.com/albums/p540/i8aford/89dde004.jpg
