Curtesy light won't turn off, help!
Where is the dimmer located for the curtesty light in the rear view mirror. Mine started flicking when I hit a rough spot in the road now won't turn off at all.
Originally Posted by wrencher
You mean the map light?
Is the switch screwed up??
If you have to, disconnect the rear view mirror harness.
I suppose disconnecting the harness would be better than pulling the fuse. Would rather fix it.
Originally Posted by WS6 RULES
Dimmer switch is wheel by headlight switch, at least on 2000 and now my 2002.
wrencher
Originally Posted by Larry
I meant the part that controls the light delay after shutting the door. I don't think that is controlled with a switch.
The time delay is a BCM fuction, this looks like a problem that is gonna need to be diagnoised.
Body control module, if your problem is not in the rear view switch it prolly lies here & will have to be found........
