Pontiac GTO 2004-2006 - will a 235/40/19 fit
lo&sloSierra
02-19-2012, 10:56 AM
Im running a 235/35/19 on the rear of my car now with a 35mm off set on i think a 8 in. wide wheel, will a 235/40/ 19 fit on stock suspension, its an 06 if it matters
Dyno Junkie
02-19-2012, 03:22 PM
Should fit on the rear, but definitely will not fit on the front.
Death{AW}
02-19-2012, 09:09 PM
why are you running such narrow tires? yea those will work easily on back unless you are lowered like crazy
redtan
02-20-2012, 08:24 AM
They'll fit sure, but if you hit a big bump or launch hard the taller tires will probably rub on your fenderwell.
Cruising it will be fine as you should have plenty of gap between the top of your tires and body, unless you are slammed.
scphilli
02-21-2012, 07:34 PM
Skinny pants
lo&sloSierra
02-23-2012, 10:11 PM
Okay so I was wrong the rear wheel is a 8.5x19, with a 45mm offset, how big of tire can I stuff? And its not lowered. Thanks.
redtan
03-02-2012, 01:02 PM
With an 8.5" wheel and that offset, the most you can go is a 255 tire.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
