broke my ls6 can i drop in a 5.3?
Old 02-19-2012, 04:13 PM
lavoy's Avatar
Default broke my ls6 can i drop in a 5.3?
as the title says i have a car with a boosted ls6 i broke 4 of the pistons, can i drop in a 5.3 and reuse all my ls6/ls1 accessories and peripherals? examples being my ls6 sensors and intake and water pump and timing cover ect ect basically every thing from my ls6 on the 5.3 maybe even my ls6 heads and cam ect. whats the deal with reluctor wheels? does a 5.3 have the same as a 04 ls6 so i can plug and play all the sensors as they are.
Old 02-19-2012, 05:54 PM
mcfarlnd's Avatar
Reluctor wheels are the same. Make sure you get a 00-07 classic otherwise, you will run into the reluctor wheel change. Other than that, everything should swap right over.
