Cam install
Cam install
Since my motor is on the stand can I install the new cam in it upside down to prevent the lifters from dropping? This may be a dumb question but I'm just wondering...
sure you can. but if the motor is out of the car it doesn't really matter. the scare factor of having a lifter drop is more for someone doing a cam swap with the motor in the car. for you it would be easy to remove the oil pan to retrieve the lifter if it fell.
You should stop posting bad advice.
rebuilt the motor due to a spun bearing. i got the motor back in the car today. it doesn't want to start. it cranks and crank and cranks and then eventually starts. what's up, what could be wrong, car fired right up before the rebuild. stock cam, ported heads and bored over a little bit... do i need a tune?
He's got some growing up to do. And some learning about engines, for that matter.
I saw the post count on this thread went up since last I read it. I clicked on it thinking I was going to learn more about the cam change subject......
nope, just insults.
nope, just insults.
The quote your talking about was on a customers buddy's LS2 rebuild. The motor was built perfectly and to spec. The reason it was having a hard time starting was we had a segmented cam gear installed and we needed the half moon cam gear. We swapped cam gears, car fired right up and has been running strong for 8,000 miles now. So **** YOU cornholio. If your going to bash people by using copy and paste from other posts then you need to put the quote into context. As far as growing up goes, im grown *******. I just don't take **** from a ****** internet "expert such as yourself. So once again get your facts strait and **** YOU
Wait a minute...you're running a garage and coming here for advice on how to undo your screwups? That's what all of your posts are really about?
BWAHAHAHAHAHAHA!!!
Then it wasn't built perfectly, was it?
BWAHAHAHAHAHAHA!!!
