Need help with truck harness
Old 02-21-2012, 09:38 AM
Joe69z28's Avatar
Default Need help with truck harness
I'm in the planning stage of a 5.3 swap. I'm thinking of using a L33 with a truck intake. My question is which harness would be better or easier ? Should I use a 99-02 harness and go dbc or try to find to find 05-07 harness that was for a L33 and go dbw ? Like to know the pros and cons of each.
Old 02-21-2012, 09:44 AM
BMF_Racing's Avatar
Thumbs up
I went with DBC with all of my lsx projects. DBW will give you the cruise control options, but you will need the throttle pedal out of the vehicle the engine came from and complete wiring harness and Tac box.
DBC was easier for my projects and the cruise control wasnt a big deal for me, but if you do alot of street/hgwy driving it might be nice to have.
Either way good luck.
Old 02-21-2012, 09:47 AM
garys 68's Avatar
Get the harness, pedal, and TAC with the engine. Clean up the harness yourself.
Old 02-21-2012, 12:37 PM
Docked Wage's Avatar
Personally I found the DBW was easier than dealing with the mechanical aspects of a Cable System.
I'd say that if you are comfortable with working with and fabricating brackets and adapters or chasing down the right piece verses the 8-10 wires that a DBW setup adds go with the cable system.
As far as fabricating brackets goes on the DBW, the only thing you will need to figure out is how to mount the pedal.
Old 02-21-2012, 12:44 PM
LS1Tech Sponsor
psiconversion's Avatar
Boils down to personal preference. But as stated above, if you decide to go DBW, do yourself a favor and get the tac/pedal/tac harness from the donor vehicle as you will reduce cost. If you cant find them, we have them in stock. PM or call us.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 02-21-2012, 01:05 PM
Joe69z28's Avatar
Does the 05-07 dbw harness make a cleaner harness than a old dbc ? Is one easier to repin than the other ?
Old 02-21-2012, 03:19 PM
68BBChevelle's Avatar
Dont know if it will work but i got a harness from an 03 lq4 with pedal and tac. Pm me if interested.
Old 02-21-2012, 04:25 PM
garys 68's Avatar
Repinning is a pain.
Changing to DBW involves repinning and reprogramming for the MAF, IAT, and IAC. Keeping DBW eliminates that and gets you easy cruise control.
The only addition is the pedal to TAC harness. That cost me $35.
Old 02-22-2012, 08:26 AM
Joe69z28's Avatar
Don't know what you mean by changing to DBW. If the engine is a L33 it has the correct sensors for a 05-07 dbw harness , does it not. I think what your saying is stay dbw.
Old 02-22-2012, 08:56 AM
garys 68's Avatar
Sorry that should have been "Changing from DBW to cable"
Keep the DBW.
Old 02-22-2012, 08:58 AM
Chavezdel's Avatar
Sorry to jump in on your tread, but I'm looking to clean up my own harness, my question is where can I find instructions to do so. Once again sorry for jumping in.
Old 02-22-2012, 09:15 AM
garys 68's Avatar
Search for "pinouts" here and this site:
http://www.lt1swap.com/
Old 02-22-2012, 11:38 AM
Joe69z28's Avatar
Keep the DBW.
Thanks for clarifying, thats what I thought.
Old 02-23-2012, 10:45 AM
Joe69z28's Avatar
Should get the original fuse box or can I adapt a smaller one from another car after its repined ?
Old 02-23-2012, 05:49 PM
FastKat's Avatar
Agreed and agreed. Wiring a DBW setup was a lot easier for me... but I really like wiring. It usually comes down to personal preference!
PSI
Old 02-23-2012, 10:03 PM
LS2 67GTO's Avatar
I've done both, IMHO it was easier just to get some aftermarket fuse holders and relays and start from scratch. First swap I used a 5.3 underhood fuse box and It was a pain repinning it and its not as compact as the aftermarket ones.
Old 02-23-2012, 10:24 PM
Rocketrod's Avatar
So what aftermarket fuse holders and relays did you end going with?
Old 02-23-2012, 10:25 PM
FastKat's Avatar
I used a fuse box from a 2008 Impala and if I had to do it over again, I would also probably get a new fuse/relay box and start from scratch. There are some nice aftermarket ones out there. They are not cheap, but they're money well spent IMO.
Old 02-23-2012, 10:41 PM
garys 68's Avatar
Aftermarket fusebox for the whole car that integrates the LS fuses.
And you'll need a relay panel, here's a great deal on a 4 gang: horn, fuel pump, 2 electric fans.
http://www.haywireinc.com/index.cfm/...rod/prd167.htm
Old 02-24-2012, 08:35 AM
LS2 67GTO's Avatar
I used these, Painless Performance Products 30002. Because I only needed a harness for the engine. For relays I just used individual relays that I mounted to fender.
Quick Reply: Need help with truck harness
