LS3 Turbo Head Gasket Advice
Bought a complete built LS3 for a customers car. Here are the specs. Was told from the seller the last owner put the long block together in his garage but the Bottom end built professionally. Not that I don't trust anyone but when doing a customers cars I want things to always be right. Going to pull the heads and have a machine shop inspect everything. Going for close to 900-1000 HP on this build. Did a quick search on the forums but came up blank. Can someone who knows just shoot me a good head gasket to run. I have heard some feedback on the cometics. Just want to hear a little more before I order some.
Tony
Shortblock professionally built by Bruce Melton @Powrmax
Diamond 11553 pistons with coated skirts -9:1 with 70 cc heads
Built on new LS3 block
Callies Compstar forged 3.62 stroke crank, 6.2 L
Clevite bearings
Cloyes timing set
Manley pushrods
LS7 Lifters
Synergy Custom Cam by Rick @Synergy
Heads professionally built by Dave's Engine Machining (Next to Synergy Motorsports)
Ported/polished LS3 heads
Comp 921 dual springs
Manley stainless valves
Tony
Clevite bearings
Cloyes timing set
Manley pushrods
LS7 Lifters
This engine is no where near stock and is going to be quite a bit past "Mildly Modified" pushing 20+ lbs of boost. Have you used these on your Turbo engine with no problems.
Tony
