brand new 160lb bocsh injector $600, free shipping
Category: Accessories
Price: $600
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): AL
Item Condition: Brand New
Engine: LT1/LT4
LS Engine?: Fits LS Engine
GM:
* 1990 deville 4.5 V-8
* 1991-95 deVille 4.9 V-8
* 1986-2004 Chevrolet Corvette
* 1985-2002 Firebird 5.0L/5.7L
* 1985-2002 Camaro 5.0L/5.7L
* 1994-96 Caprice 4.3 V-8
* 1994-96 Chevrolet Impala
Static Flow Rate: 152lb/hr = 9.42g/s = 1680 cc/min (+/-4%)
Dynamic Flow Rate 2.5ms PW @ 100Hz: 16.9 mg/pulse (+/-4%)
Coil Resistance: 2.35 Ohms / Low Impedance / Low-Z (Peak/Hold driver circuit required)
Connector: Minitimer (Bosch EV1)
Factory fitted with Viton upper and lower o-rings.
These injectors flow 1600 cc/min at 43.5 PSI ( 3 BAR ) and are fully compatible with alternate fuels and alcohol! Some websites may refer to their flow rating as 160 lb/hr or 150 lb/hr or 1680 cc/min Bosch Low Impedance Injectors. Frequently used in racing, flex fuel applications and alternate fuel applications, these low impedance injectors combine extremely high flow rates with excellent response at low pulse widths! This allows you to use a larger injector than normally possible without hurting idle and low speed drivability.
These injectors are able to function at high fuel pressures and don’t exhibit the high fuel pressure handling problems found with many other high flow high-impedance injectors. This makes these injectors very well suited to turbocharged and supercharged applications that see high fuel system pressures.
