how hard can i launch her?.
Going to the strip this year for the first time. Mods are in sig, stock tranny internally, diamind stage 2 clutch... probably ordering these parts next friday.
MWC 9"
-35 spline lightened spool
-Strange nodular center section-back brace-aluminum daytona pinion support
-3.89 gear
-LCA relo Brackets
-PST 3.5" Drive shaft with forged yokes
MWC SFC weld in
MWC adj panhard bar
MWC adj lower control arms
MWC adj torque arm
MWC cross member w/ driveshaft safety loop and relo bracket for torque arm
Strano sway bars
Strano springs
bilstein shocks (maybe single adj konis)
Founders performance strut tower brace
MSD 2-step
SLP line lock
How hard should i launch her?. What to expect....ET guesses?. Decent setup?
MWC 9"
-3.89 gear
-LCA relo Brackets
MWC SFC weld in
MWC adj panhard bar
MWC adj torque arm
Strano sway bars
Strano springs
MSD 2-step
SLP line lock
Thanks to thr ppl that were actually helpful. As far as a tire, Im not sure yet. MT or hoosires. Dunno what size i should run Ir what width wheel. 15x8, 15x10... i figured id start at like 2500 and go up. Im not sure how much rpm the stock tranny can take.
I would try 4k with a light slip and go from there. I can't talk from
Exp bc I haven't been able to take my car to the track since I put the blower on it. But when it was N/A it worked very good for me an that was on street tires. Good luck
just cause i like this vid
[youtube]PHzOcd4zKzk[/youtube]
dont worry about the drivetrain, what you posted is plenty strong, when i was h/c/n20 i would launch just shy of the limiter
all good info above for the most part, you will need to keep the rpms higher than 4k and with 3.89 rear gear you will have to ride the clutch a bit to keep from bogging or having to much wheel speed. I could see that set up doing 1.5x 60's with some m/t 28x10.5 stiff sidewalls.
