Another cam spec'ing post!
So Pat spec'd out a cam for my C5Z and things have slightly changed since then. I now posess livernois stage 3 243's 62cc chambers, no more nitrous and I want it to have a manly idle lol I want this thing to sound mean! I still want to retain the same power band of the current cam. Rev limiter set at 6800-6900... And it needs to be drive able down low and stay punchy in the mid range...
https://ls1tech.com/forums/generatio...cd-my-z06.html
I agree with all of that. Just wanting opinions on the LSA and the exhaust side. Intake is staying at 230
Was kinda trying to get out of another $25 spec'ing fee is all lol
If it was me I would use the same cam. I doubt he will make much change in the specs , may 112 LSA. I bet there isn't much if any difference on exhaust flow between the 2 heads. Probably intake flow and higher in the lift range than your cam will be. Like th eother guy said, he may adjust them for you at no charge. I would at least contact him and see.
LS1 Tech Administrator
I would tighten the LSA and exhaust if you're not going to run nitrous. I'd run that 230 EPS lobe on the intake with a 111LSA on a 109 intake centerline. For the exhaust, I'd run a 230 LXL lobe if you wanted better power and street manners in the 1500-3500 rpm range or a 234 lobe if you valued power above 6500 rpm more. For what it's worth, the 230/230 111LSA cam has the same 8 degrees of overlap as the 230/238 113LSA cam.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
