Milled 317s PTV clearance with big cam?
Old 02-22-2012, 02:08 PM
vladsvt's Avatar
Default Milled 317s PTV clearance with big cam?
So I have a good deal on 317 heads, there pretty much new and cheap. Currently I have 241s that are semi ported.
I was wondering if I were to mill the 317s down to about 66cc (or whatever a 243 head is) what's the biggest cam that can fit?
I am looking to use a Whiplash II cam which is mid 240s, and around 630 lift 113LSA.
Old 02-23-2012, 12:35 AM
ScottyBG's Avatar
I'm not a professional, but I think you will have PTV issues unless you flycut. No way would I try to run that without measuring it. I have milled 317's, maybe a little more than what your looking to do, to about 62cc, and a 226 intake lobe (on a 113 as well) gets you to about 0.065-0.070 clearance, which is cutting it close. The convention I've heard used is 0.080 min on the intake, and 0.100 on the exhaust. Now the profile of the lobe plays into this, but a 245is lobe is probably more agressive than what I have. Even if you were not milled at all, I think that would be cutting well into the safety margin. I would guess that about the biggest you could safely run would be about a 230ish cam in those heads, unless you went to a wider LSA. I'm not sure what your looking for, I would guess a race car only, no street use with a stick that big? From what I have read on those Whiplash cams is they are typically used on larger displacement engines like LS7s.
Old 02-23-2012, 01:51 AM
Blk98Vert's Avatar
I don't see why not, they make a point to say their cams work in stock LS6s.
Old 02-23-2012, 11:45 AM
vladsvt's Avatar
Thanks! My current pistons are already flycut (Ross forged ones) so thats good. My motor setup is a sleeved 378 ls1, so I'm looking for a bigger cam to help out with top end. Currently it has a comp 236/232 and its pretty much "tq" it made something like 430/425 (on ls6 intake, ls1 heads ported). Whiplash II might seem big but there used plenty of stock or semi stock ls1s with great results, and the cam should work even better with my setup. I just want a all around street car with great manners (and it seems that that big of a cam it drives really good).
So milling them down to 243 chamber size and flycut pistons should work?
I would ideally go with a set of LS3's since my bore is over 4.00 but Im replacing alot of stuff so I'm tight on budget and found these 317s super cheap locally
Anyone else has any input?
Quick Reply: Milled 317s PTV clearance with big cam?
