2006 Honda S2000 Immaculate! 500+whp TONS OF EXTRAS
Year: 2006
Make: Honda
Model: S2000
Price: $25000
Mileage: 42000
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Silver
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has other engine
$25,000 with wheels
$23,000 without
hondata flashpro with boost by gear
pfab vband topmount manifold
apr manifold studs
pfab 3in down pipe, custom wastegate dump
pfab stage 2 intercooler with 2.5in pipes and t-bolt clamps
gtx3076r .82 tial housing
tial q 50mm bov
precision 46mm wastegate
id1000s injectors
inlinepro fuel return system
fullblown 340lph pump
sos 4 bar map sensor
odyssey mini battery kit
dual guage pillar pod
aem wideband
defi boost guage
CC 6 puck clutch
puddy stage 3 rear diff(not installed)
exedium solid rear diff mounts(not installed)
ac relocation kit
supra pcv valve
sp boost actuated exhaust cutout
Ksport control pro coilovers
DP Motorsports AMP 3 piece wheels(Very rare with center caps)
Tires are a month old with less than 1500k miles on them
Rear end build - SEE PICS:
balancing the carrier and the ring gear, balance is at 7/10th of a thousands true round
PuddyMod solid steel sleeve being set
turning torque on the pinion after the PuddyMod solid steel sleeve is custom fitted, it is set at 12 inch pounds
backlash set at 2.9 to 3.3 thousands, it also shows the perfect gear to gear pattern
Use Amsoil synthetic severe Gear 75/140 gear oil every 6K miles.
