Drag Racing Tech - Question on 6 point roll bar
69gto96z
02-22-2012, 07:18 PM
I recently purchased a 6 point jig notched roll bar from a board member for very cheap. He bought it a few years back, and never did anything with it, other than let it sit in the elements. It has some rust, but I am in the process of sandblasting it piece by piece at work and prepping it for paint. My question is, the roll bar has a removable cross bar. I know this is NOT NHRA legal, but if I weld the cross bar in place, so that it is no longer removable, would that pass tech, or would they still gripe about it? If it won't then I won't bother to weld it up.
sweetbmxrider
02-23-2012, 10:10 AM
If the cross bar is properly welded in, it isn't removable anymore? You shouldn't have a problem.
69gto96z
02-23-2012, 06:52 PM
The crossbar welds in yes, but has pins much like a removable swing arm to be able to take it out. I was thinking of welding the joint up and removing the pins to make it 100% not removable.
black and pink z28
02-23-2012, 07:41 PM
if you weld it you should be ok how far pass 11.49 are you if the are only goes like 11.30s ur sum thing they may nt never say any thing about it if its not weld my home track is very lenient on sum things
69gto96z
02-23-2012, 08:06 PM
I am shooting for 10.50's.
black and pink z28
02-24-2012, 08:51 AM
I would weld it then
sweetbmxrider
02-24-2012, 10:40 AM
Right I understand that. I meant if you fully weld the bar in so you can't remove it, you will be fine.
69gto96z
02-24-2012, 11:00 AM
Okay, im sorry I misunderstood what you were saying. Thanks guys!
94Z28rag
02-24-2012, 02:49 PM
I agree with the above. You shouldn't have a problem.
Don't know if you've tried it, but white vinegar removes rust very well. Might help you speed up the process.
69gto96z
02-24-2012, 03:01 PM
It takes about 15 minutes per bar sandblasting it, not long at all. Only time I have to work on it though is my lunch break, so it will just be a drawn out process doing 1 bar a day.
