are torsen limited slips rebuildable?
can they be rebuilt or shimmed? my posi seems to be alil worn out. i ordered gears and i figured while im in there ill fix it as well. so what can be done to them? thx.
Moderator
The Torsen was alleged to never need rebuilding, because
it works by binding metal and not frictions. But I found a
lot of that metal at the bottom of the pumpkin, and as
tolerances get bigger I bet the effectiveness gets less.
Now a lot of people think their Torsen is bad just because
they get a one-wheel peel. But that's the nature of the
piece and its low bias limit, to some extent.
Jimmy is right, it will not act like a spool. You can still one wheel peel with it at times. But, in a relative straight line it should leave two almost identical blackmarks from my experience.
well i was jw because i had it on a lift and spun one tire and the other barely moved lol. it does seem to do good burnouts tho. my neighbors probably hate me by now . no big deal i wasnt planning on spending money on a new one, just fix it til i get a new rearend next yr. would it help if i ran no limited slip additive fluid in the rearend? just regular gear oil. this is my spring/summer car btw.
My torsen acted funny sometimes at the track. I'd get a one wheel peel when heating up the tires. I found sitting in the water box holding the breaks apply light gas then releasing brakes with line lock on then hammering it got both wheels going..
