RsSean
02-23-2012, 06:38 PM
What fuel are you guys using in the stand alone fuel cells? Going to go with VP fuel as it is readily available in my area. There is some many to choose from, and why are you running it? I was thinking along the lines of q16 of it be oxygenated. There is not to many thread discussing the fuels in the cells
Now the other question how are you tuning the AFR with mixed gas like 93 pump going thur the injectors and the "Q16" going thur the nitrous solenoid? I guess the target AFR would be different.
How do you go about tuning on different gases?
Back ground, 383 Forged motor built to spray, Nitrous pistons, Callies crank, Compstar rods, 11.8 to 1 motor. Want to say the rings .025 top and .028 could be mistaken
Thanks guys
Thanks guys
