2002 Firehawk rear end swap,, AAM?
Old 02-23-2012, 10:08 PM
willy9's Avatar
Default 2002 Firehawk rear end swap,, AAM?
So I have a 2000 WS6 and I broke the rear end. I got a used one from a 2002 Firehawk and it says AAM and I was wondering if this was the optional differentials that the firehawks had and if it is what "special" about it?
Attached Thumbnails 2002 Firehawk rear end swap,, AAM?-111111111222-differe-nt.jpg   2002 Firehawk rear end swap,, AAM?-11111-differential.jpg
Old 02-23-2012, 10:18 PM
willy9's Avatar
Also I forgot to mention that my car did not came with traction control but the firehawk differential that I installed had it,,, How can I make it work?
Old 02-23-2012, 10:28 PM
joe77's Avatar
you cant as your car is a 3 channel not a 4 channel, the tc reads off sesors near the axel ends for abs and tc. the 3 channel reads abs off the sensor on top of the pumpkin. You will need to install the reluctor wheel on the new diff to keep abs.
Old 02-23-2012, 10:31 PM
69TA's Avatar
yeah what this guy said is correct
you got the wrong rearend
you can make a 3 channel rear work in a 4 channel car by swapping axles but it's not so easy to make a 4 channel work in a 3 channel car, you have to take out the diff and get one with the gear and then drill out the housing for the senor.
Old 02-23-2012, 11:44 PM
HoLLo's Avatar
The only thing "special" is the AAM differential cover that is supposed to be stronger and keep it cooler.
Old 02-24-2012, 01:44 PM
SSCamaro99_3's Avatar
Didn't the AAM cover and the optional Auburn defferential come as a package deal? Finding old SLP information is tough these days.
Old 02-25-2012, 10:11 AM
99canadahawk's Avatar
Yes sir you are correct ! the Auburn gold series diff came with the aluminum cooling cover .
Old 02-26-2012, 11:54 PM
7plagues's Avatar
If you are in Houston ill buy it off you. What gears?
Old 02-27-2012, 12:58 PM
Thought so. No synthetic lubricants for that dif.
Old 02-29-2012, 03:11 PM
willy9's Avatar
Im in midland, stock gears...
Thanks for the help guys Ill guess Ill rebuild the old one and drop some 410 on it.
Quick Reply: 2002 Firehawk rear end swap,, AAM?
