How much timing are you guys running 93 with Meth able to run?
How much are you turbo guys getting away with on 93 pump and meth injection (80/20)? I haven't started pushing the timing envelope yet, but once I get my short times down thats where I am going to turn for more HP. I am currently at ~11.5* (setup is a s400/lq9).
Also, how much is the jump from 11-12 to say 15-16* worth?
TT-TECH Veteran
First off I don't know anyone runing 80/20 meth mixture! But hey if it makes you feel better to add water to it, then I guess your fine then. But when I've been running it I still ended up in the 17* range depending on the car setup CR etc... every degree is going should see a decent gain until you get to a point were it won't gain much most I have seen don't ever pick up anything after 18-20* but most will do that on the dyno and then back it down a couple of degrees for saftey.
On that Kenne Bell page they say:
"At KB , we set timing at 18° and boost at 9psi for 91 octane. 93 octane allows another 2psi or 2 – 3° spark but NOT both. Higher ECT, IAT and ambient temps will retard spark via the ECM and protect the engine from harmful detonation."
That seems a little bolder than most on a 10.7:1 ls3 but they are relying on the knock sensors.
i know on my car i dont have knock sensors and once i push the envelope just gonna have to be careful. right now im running 15psi and 14 degrees of timing on plain old 93 octane.
Gingervitis Addict
OP, don't forget that the LS3 quoted by Kenne Bell has LS3 heads, which have a different chamber than typical cathedral port heads, so will have a slightly different timing curve (I know they tolerate more timing N/A, so I would expect to see a similarity boosted).
My IAT temps on a 160mph pass are in the 110-120 range using a #10 and #15 nozzle.
At this power level I don't rely on the knock sensors-I run the car on the fat side ( you can always see a haze of smoke with the car going down the track) and check the strap on the plug.
TT-TECH Veteran
On his car they do function sorta for a saftey factor, but I usually don't rely on them or run them on any of my car and haven't for a while. But if you looked at the knock sensors they weren't detecting any knock, but the car barley picked up any power from 18* to 20* so I believe we backed it down to 17* as that seemed to be the sweet spot etc... The plugs looked great etc...
I pull timing based on IAT.
