Carbureted LSX forum - Super Chevy april issue
View Full Version : Super Chevy april issue
butler
02-25-2012, 03:50 PM
Has anyone read the article on the Holley dual quad intake vs vic jr intake? Dual quad took bottom end honors by 50lb. ft torque. It stayed right with the single plane with 1 hp difference on the high end. Fairly impressive.
S10xGN
02-25-2012, 06:40 PM
It's sittin' next to my throne, you just gave me incentive to jump over my current "read"!
Doug G
02-25-2012, 07:03 PM
2-4's or 3-2's work great... until you need to tune... but drivability<sp> suffers atleast as I heard...Never had a need for 2-4's or 3-2's muddin' :D
butler
02-25-2012, 07:33 PM
2-4's or 3-2's work great... until you need to tune... but drivability<sp> suffers atleast as I heard...Never had a need for 2-4's or 3-2's muddin' :DI have no clue as to drivability. The extra grunt may be due to the dual plane design and better fuel distribution. The carbs I am sure can be dialed in a little better but they had good a/f on wot.
newschool72
02-27-2012, 02:36 PM
But , alas, still no L92 love.:bang:. That dual quad intake would be SWEET with the dual TB option on my fast EZ EFI. Hey and NO tuning. Dont matter anyway. It will take holley another 10 yrs to offer it for the big heads .:eyes:
speedtigger
02-28-2012, 11:25 AM
That is pretty good. At what horsepower level? That might change when you start moving more air.
Also, you can effectively port the Victor pretty easily. It is nearly impossible to do much more than a port match on the Performer. I have not seen the dual 4 intake in person, but I suspect it would be the same scenario.
Oh, and tuning those Carter style carbs suck.
Pop N Wood
02-28-2012, 11:42 AM
The motor was a bit of a bastard, a 5.3L stroked to a 383 with 215 heads. The thing made 527 HP at 6000 RPM. They didn't spin it any higher than that. The dual quad was also a dual plane. Probably weighted and extra 10 pounds with all that metal. Interestingly I couldn't find the cam specs in the article.
The two systems were dead equal above 5000 RPM. Have to wonder if the heads were limiting the airflow and not the intakes. Put those two intakes on on a motor with a 4 inch bore and spin them to +7K and see what happens then.
topbrent
02-28-2012, 02:56 PM
With no mention of a cam swap, I would presume the cam is probably the same one that they used in Modern Mouse pt.4 (http://www.superchevy.com/technical/engines_drivetrain/completebuilds_testing/sucp_1203_5_3l_ls_small_block_build_part_4/index.html)
Comp LSR 281LR HR13 #54-459-11
.617/.624 231/239 113+4
jarheadl34
03-01-2012, 10:45 AM
I believe they mentioned that Holley makes the same manifold for the L92 type heads and that it performed the same. A buddy swiped my copy and hasn't returned it but if you'll reread I believe you'll find it.
Jarhead
speedtigger
03-01-2012, 10:56 AM
I would like to get my hands on that Holley dual 4 intake for inspection. I want to see how large the ports cross section is compared to the Edelbrock dual planes.
newschool72
03-01-2012, 01:04 PM
I will check into the l92 dual, but sure would be nice to see a comparo . That is an expensive proposition . The extra fast throttle body is 5 bills and plumbing, then the price of the intake, yikes!
NOS327
03-14-2012, 09:59 AM
link to online article?
topbrent
03-14-2012, 05:42 PM
Here you go:
http://www.superchevy.com/technical/engines_drivetrain/completebuilds_testing/sucp_1204_5_3l_ls_small_block_build_part_5/index.html
Trip..
04-15-2012, 03:19 AM
Funniest looking "Carters" I've ever seen. :razz:
Doug G
04-15-2012, 06:33 AM
LOL.... even spelled wrong on bowl :nod:
speedtigger
04-15-2012, 11:21 AM
Yeah yeah. I was thinking of the Edelbrock set up. I guess it would make sense that Holley would design their intake for Holleys eh?
I actually drove a twin 600 Holley/Offenhauser low rise equipped 65 440 Coronet for a guy for 1 season in 1990. The set up worked flawlessly and was actually faster than his single 850 set up on that car.
ZONES89RS
04-15-2012, 12:01 PM
Well, eddy doesn't even make a intake for a spread bore, so you wouldn't know unless you were told so by insignia, just love seeing the market for carb induction steady rising.
Professional products was supposed to make a carb intake for the LS, but alas, nada...
speedtigger
04-15-2012, 07:13 PM
Carters aren't spread bores. They are square bores like Holley. They just have smaller bores. The Edelbrock carbs are just updated Carters.
ZONES89RS
04-16-2012, 09:18 AM
I know, just saying they don't even make them for the usualy eddy. And a eddy carb is a simplified carter, lol.
speedtigger
04-16-2012, 10:04 AM
I have not tried the Edlebrock version. I played with some carters on an old 63 Buick Invicta and did not do very well. It had a secondary bog/hesitation that I did not successfully tune out. However, a Holley 600 solved the problem nicely.
NemeSS
04-16-2012, 12:17 PM
Ive always wondered same thing. Pp makes manifolds for just bout as any motor, i think even seen for pontiac motors.:huh:
Even jegs makes or has there own line of manifolds. But no ls manifolds.
I been wanting to try the holley l92 plenum hi rise intake. I hear can use like tunnel ram with a single or dual carbs. Just by changing tops.
Trip..
04-16-2012, 02:12 PM
I love Edelbrock's carbs. After dealing with Holley's idiosyncrasies for years, I just gave up. I bought a 600 Edelbrock from a buddy, adjusted the idle circuits for the highest rpm, backed em off a 1/16th and that was it. It was the best running carb I'd ever had.
I tried 3 Holley's, a 600, 650 and a 700 nothing would work on that lil 350 sbc with a .454 in/ex with a 280 adv dur. Plopped the eddy on and never touched it for 3 years.
I still prefer a q-jet though... (Hides from poop-flinging) It's the sound of a properly functioning Q-Jet that get's my goat.
00BlackSS
04-16-2012, 05:44 PM
hi we are talking about intake manifolds, care to join us?
Its funny u guys are talking about PP making a carb intake manifold, i was just wondering if they were ever going to make one, id like to see some more options out there. that mast one is way to much money!
Trip..
04-16-2012, 07:36 PM
No "We" were talking about intakes and carbs, you came in and acted like a douche. Yes I got a bit off topic, point taken.
It's so cool that I got to be the first person on this board to get off topic. I'm so Awesome!
Glad to see that not everyone on this board is like you... :thumb:
...Been lurking on this board for 2 years before I even signed up, make 2 posts and I'm already having to deal with forum police... Nice.
My apologies to Butler, the OP.
00BlackSS
04-17-2012, 05:35 AM
its a joke, take it and enjoy ur day, please dont get to butt hurt! :gtfo:
