Gforce Engineering
02-25-2012, 10:26 PM
I wanted to let everyone know about some exciting new driveshaft developments that we have been working on the last few months.
We talked to DynoTech Driveshafts at SEMA about making the high end splined slip style driveshafts they make for the newer Mustangs available for the CTS-V's.
They have the expertise in designing and manufacturing some of the most high tech driveshafts on the market and we have the expertise in drivetrain components and how to mount the shafts to the transmission and rear diff.
So we designed a billet steel adapter for the front and rear to bolt these new driveshafts onto the CTS-V's.
The new DynoTech splined slip shafts are nothing like the old school steel shafts that you would find in a truck or an old school hot rod.
These are all aluminum splined slip shaft assemblies designed with a tightly fitted splined assembly that lets the shaft plunge in and out but also gives the shaft the ability to spin vibration free and be incredibly strong.
The splined area comes with a boot to protect if from dust and other road debris.
The front of the shaft uses a solid core 1330 series u-joint, the rear gets a larger 1350 series u-joint.
These high end u-joints that Dynotech uses even come with delrin cups on the grease caps!
Now onto the good stuff, since there is no cv joint on the front or back of these shafts you get a substantial weight savings.
No cv joint also means you don’t have an extra 5 lbs sitting on the front of your driveshaft to put stress and loads on the output shaft and seals.
It also means you don’t have a cv joint that might wear out or need serviced.
A stock manual transmission driveshaft weighs in at 24 lbs. The new DynoTech shaft weighs only 14 lbs. That is a full 10 lb reduction in the rotating mass!
These shafts are a proven performer in the Mustang market and are rated to 900hp and have been to speeds well beyond what we would consider highway speed LOL
The new DynoTech shafts will sell for $899. and comes with our billet steel adapters for the front and rear that are machined to positively locate in the stock 3 finger yoke for a perfect fit and alignment.
The rear adapter bolts right up to the stock yoke.
Here they are on our web site
http://www.shop.gforce1320.com/product.sc?productId=197&categoryId=61
We will also offer this shaft with our 9" kits. You can get the new 1 piece or the 2 piece that we have been selling.
http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/Dynotech%20Camaro-G8%20Driveshafts/2010Camaro-CTSV-G8.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/Dynotech%20Camaro-G8%20Driveshafts/2010Camaro-CTSV-G8frontadapter.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/Dynotech%20Camaro-G8%20Driveshafts/U-jointcloseup.jpg
Here is the same shaft installed with our 9" kit in a 2011 Camaro, the CTS-V driveshaft is just a bit longer, other then that they are the same.
http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/BullF-16%209%20Inch%20IRS%20Install/DSC00222.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/BullF-16%209%20Inch%20IRS%20Install/DSC00218.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/BullF-16%209%20Inch%20IRS%20Install/DSC00225.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/BullF-16%209%20Inch%20IRS%20Install/DSC00236.jpg
