Has anyone installed a oil pan gasket without rtv?
Old 02-26-2012, 12:41 AM
DavidGXP's Avatar
Default Has anyone installed a oil pan gasket without rtv?
What was the outcome after install?
I put a new felpro gasket on and didn't use any rtv. After reading through my service manual, it said to apply a dab in the four corners. Well.... F****! I just dropped the engine in last night!
Old 02-26-2012, 07:32 AM
davidws6's Avatar
Just where the pan meets the front and rear covers. Though if you didn't you might be ok cause of the rubber seal type gasket.
Old 02-26-2012, 11:16 AM
DavidGXP's Avatar
Anyone else?
Old 02-26-2012, 11:39 AM
Fade2blk500's Avatar
I've done it without rtv, no leaks yet..
Old 02-26-2012, 11:48 AM
Hank Peabody's Avatar
I didnt realize you were supposed to use rtv. Ive taken pans on and off about 8 times now on LS/LQ engines now with no leaks.
Old 02-26-2012, 12:01 PM
DavidGXP's Avatar
Thanks guys.. Makes me feel a little better.
Personally, I don't like the idea of using rtv around anything internal.
Old 02-27-2012, 02:36 AM
Sawzall and Welder Mod
Whistler's Avatar
If you do develop a leak it will be very small and residual in nature. No dripping leaks from that.
Old 02-27-2012, 03:41 AM
chrisfrost's Avatar
As long as You're PCV system is working correctly at keeping a slight vacuum in the crankcase You should'nt have any significant leaks for a long time .
Old 03-07-2012, 05:26 PM
DavidGXP's Avatar
Works just fine with no leak:-)
Quick Reply: Has anyone installed a oil pan gasket without rtv?
