Florida Members - Went 11's in my bolt on 08 corvette
corvet786c
02-26-2012, 03:48 AM
Did 1.745 60ft into 11.94. The other car was a 08 GT500 with a pulley 3.73 gears and intake pushing over 550 hp.
My car is a 6 speed manual and has headers, tune, and intake other wise everything else is stock. Plus the DA was 1100 and around 75* Still learning to shift this thing and only gettin better.
blk/slvr02ss
02-26-2012, 08:22 AM
Finally but i still dont know why your MPH is so low you should be trapping mid 120's !!! Does you brother want to buy the headers and air intake off my old Vette ?
corvet786c
02-26-2012, 08:49 AM
No, thanks he already has them, thanks anyway. I am thinking the da was around 1100 dont know if that has anything to do with it. Most of the M6 on corvette fourms are trapping around the same with bolt ons give or take a couple of mph. Maybe better on a cooler day.
Next time I am trying to get a 1.6 60ft see if thast helps a lil more.
blk/slvr02ss
02-26-2012, 08:52 AM
Could just b the A6's Traps higher than a M6 cause of the 2:56 gear in it were as a F-Body the M6 Traps higher than a A4 !
Imstock2
02-26-2012, 08:58 AM
should invest in a go pro.. Once you get und pulley, ported fast intake and tb you'll improve your times and et like no other. All though it is cheaper to do a mild cam set up,milled heads and get your intake ported as well as your Tb and you will gain a hell lot more then a fast 102 with 102 Tb. How do you like the 3.90's? I'm swapping my differential to that soon
corvet786c
02-26-2012, 08:59 AM
Joe look at this slip between me and the GT500 so close. He had a pulley intake and gears.
corvet786c
02-26-2012, 09:01 AM
Could be cause I am in 4th towards the end of the 1/4 mile.
corvet786c
02-26-2012, 09:03 AM
I actually love the 3.90's. More seat of the pants feel and better fun factor. GM should of had that from the factory. I am running 275/40/17, so with the gear and 25.6 diameter tire its like a lil more than 4:10 gear. Its steap.
Imstock2
02-26-2012, 09:13 AM
Yea I'm looking forward to it. I have 285/40/18s as my drag set up. With 3.90s are you still getting 32mpg+ cruising 65mph?
blk/slvr02ss
02-26-2012, 09:18 AM
Yea it all depends on a lot of different things !!! My slowest time was 12.00 @123 w/ a 2.01 60ft !
corvet786c
02-26-2012, 09:47 AM
If I have the 18's up front and 19's out back more like 29-30mpg. Also their is a slight whine, but it doesn't bother me at all.
sully28
02-26-2012, 01:49 PM
Time to bring it to Lashway for a cam and retune :)
littlefranks
02-26-2012, 10:00 PM
thats pritty good times with what you have .cam her up and some better 60s .high 10s in the future.
Congrats on ur time. I think that Shelby has more then an 11.9 in it with the mods u said, unless it was on street tires.
corvet786c
02-27-2012, 04:37 AM
He also had MT drag radials and went 11.687 @122 with a 1.784 60ft
I raced him on that run with a 1.745 60ft 11.942 @ 119.
He said his best was like a 11.4 during cold weather.
Overall it was a good run he came up to me and said man you can bang those gears on that vette, we both laugh cause it was a close race. He thought I had a supercharger or something on the vette where it is just bolt ons and gears.
He also had 3.73 gears as well
