Randon assortment of parts needed
Looking for multiple things, will take used stuff as long as condition is good.
ARP Rod bolts (99 LS1)
ARP head bolts (99 LS1)
LS Wiring harness (truck or car, doesn't matter, with PCM)
Autometer Oil, water, fuel level, speedo, trans temp guages
Hurst 1/4 stick but will consider others as long as it works with a TH400
Trans Cooler
3000-3500 Stall for TH400
Fbody Oil Pan/pickup tube/windage tray
4:56 gears for Ford 8.8
Trans Cooler
I have a harness and pcm froma 2004' LQ4, only thing is when they pulled the running engine, the wires down at the starter were cut, rest of harness and plugs are original
Harness and pcm $150 shipped to you
