afr heads with zo6 cam!?
Old 02-26-2012, 02:12 PM
00_LS1_T/A's Avatar
Default afr heads with zo6 cam!?
So i wanna buy some 210cc afr heads and i wanna put that zo6 cam in it.. any of u guys done this or know anyone that has!? I don't know much about ls1 and upgrading them.. how do u guys think that little setup Will perform!? Car is a 01 trans am ls1 its pretty much stock just exhaust and ported tb.. thanks
Old 02-26-2012, 02:23 PM
00_LS1_T/A's Avatar
Link for heads.. http://www.ws6project.com/user_stor/...oducts_id=4558
link for cam.. http://www.ws6project.com/user_stor/...2-zo6-ls6-cam/
Old 02-26-2012, 03:33 PM
redtan's Avatar
Why go through all the trouble of doing a cam swap only to put in a tiny *** cam?
Old 02-26-2012, 03:35 PM
got milk??'s Avatar
I guess I will bite first on this one, those are top shelf heads. A lot of people are going to tell you go with "blah blah cam" I will say that the Z06 cam is a great GM piece that was designed for a beast of a car. You have to take into account that the cam was still specd for parts reliablity, wear and tear, mpgs, emissions etc. It has alot of external forces at play. Depending on where you live you can give up say emissions and mpgs for more performance. I am not going to say there are better cams out there because that all depends on what your goals are, but you can do good research to see what other cams will net you as well.
Old 02-26-2012, 04:23 PM
00_LS1_T/A's Avatar
Reason why i don't wanna put a big cam is cuz i want it to be idleing all crazy u know... its my dd i go everywhere on it... and a big cam attracts Alot of attention from cops and i don't want that.. Am a big fan of afr head that's why am going with them.. unless there's a bigger cam that idles like stock then ill look into that.. u guys know of any cam that can do that??
Old 02-26-2012, 04:53 PM
Rise of the Phoenix's Avatar
Two words: Tony Mamo: He can spec you a very small cam that will idle like stock and perform much better than the Z06 cam.
Old 02-26-2012, 04:56 PM
00_LS1_T/A's Avatar
Really!? how can i get a hold of this tony fella!?
Old 02-26-2012, 05:39 PM
Flamed99Z28's Avatar
You can do a search for tony mamo on here and send him a private message.
Old 02-26-2012, 06:47 PM
00_LS1_T/A's Avatar
Ok koo thanks man... how would u think a small cam with those afr heads Will perform!?? am not looking to have a fast *** car but i want something ok u know... Am also thinkin of putting that fast102 intake and some tsp lt.. should work good no?
Old 02-26-2012, 07:03 PM
Have a talk with Tony, let him know what you're after and he will get you set up. Tony spec'd me out a cam, ported my fast 102, and set me up with some sweet AFR215s. Just be honest and realistic about what you are after. He is a great guy to work with. I'd post up some numbers from my build but I still have a few things to get worked out before I can get on the dyno.
Old 02-26-2012, 07:09 PM
00_LS1_T/A's Avatar
I gotta talk to Mr tony so he can help me out with my build... those he work on his customers cars!? Like put the mods on the car!?
Old 02-26-2012, 07:23 PM
Z28SteveA4's Avatar
tony's the way! Another great guy is pat g who has spec'd thousands of cam for people on this site and far beyond. At the same time i am a believer in the ls6 cam. There is a guy on this form whos cam only running 10's with an ls6 cam. the cam doe make good power and i feel like it would love the afr heads. Talk to one of these guys and they will be able to give you exactly what u want but make sure you know what other mods you will be doing before you talk to them. they will want to know everything to get the cam correctly fit for you.
Old 02-26-2012, 07:48 PM
00_LS1_T/A's Avatar
Wow 10's cam only!!?? that's amazing! well when i get a chance am gonna contact Mr tony and Yea im gonna tell him everything am planning on putting on my ls1
Old 02-26-2012, 08:29 PM
A.R. Shale Targa's Avatar
Tony can set you up with a cam in the 220-224 duration that when matched
with the 210 heads can be tuned to idle & run like stock manners, plus even
get improved mileage.
Old 02-26-2012, 11:38 PM
99Bluz28's Avatar
Here's a few that would a better choice then the Z06 cam.
http://www.ws6project.com/user_stor/...-lift-212-218/
http://www.engpwrsys.com/index.php?a...od&productId=4
Maybe even a TSP 220/220 w/115lsa
http://www.texas-speed.com/p-1145-te...-camshaft.aspx
Old 02-26-2012, 11:45 PM
00_LS1_T/A's Avatar
The higher the lsa the quiter the cam becomes!? sorry i dont know much about cam spec
Old 02-27-2012, 01:48 AM
99Bluz28's Avatar
Here, read this:
http://www.compcams.com/Pages/416/va...-tutorial.aspx
http://www.compcams.com/Pages/413/ca...ion-angle.aspx
4. How does increasing or decreasing duration affect my engine performance?
Duration has a tremendous amount of affect on engine behavior -most notably, the rpm at which its peak torque is produced. Shorter duration camshafts (or “mild” cams) produce more low rpm torque, while camshafts with larger duration (or “bigger” cams) will tend to increase upper rpm horsepower at the expense of low rpm torque. In general, for every 10° increase in duration, the torque peak of the engine moves up by 500 rpm.
Old 03-02-2012, 06:53 PM
MonmouthCtyLS7's Avatar
Top of the line heads w/ a shitty cam....imo its a waste of the heads lol
Old 03-02-2012, 07:24 PM
Killer5.3's Avatar
The LS6 is a very good cam ,but, Tony favors single pattern duration cams with his heads or no more than 3-4 degrees split. He can spec you a small grind that idles stock and will make better power with the AFR 210 heads than the LS6 cam.
Old 03-02-2012, 08:54 PM
garygnu's Avatar
for a few more dollars then a z06 cam you can make alot more power with a cam from Tony Mamo.he works for air flow research .
Quick Reply: afr heads with zo6 cam!?
