Small Block & Big Block Chevy Specific - 468 bbc or 496 bbc
dkcoleman01
02-27-2012, 09:50 AM
I have a stock bore bbc 454 (bare block) that I am needing help deciding what to build. I want the engine to run pump gas with 10.1 compression ratio. I want it to be a Daily driver/Weekend warrior. Budget ~ 4000$
Which engine would be best to build a 468 or 496 stroker? And Why?
Thanks in advance
dkcoleman01
02-29-2012, 07:28 AM
Has anyone had any experience with either bbc?
mrdragster1970
02-29-2012, 09:54 AM
For something so low powered, I honestly would get whatever the best bang for the buck is.
If you could ever afford a real high performance build,
then you would definitely see a noticeable difference from a bigger arm.
Now also be careful you don't get fooled by all the china crap and their inflated numbers.
It might look like you are getting way more for less, but most of that stuff sucks and needs a lot of money to fix all the issues.
Plus the stuff breaks with regularity that a decent American, base model part doesn't.
Good luck.
torqflyte
02-29-2012, 12:51 PM
Hi DK, I'm also building a 496 and have researched extensively into my build. You'll spend almost the same amount for each size build. You'll be a lot happier with the 496.You'll get tons of torque, 600 ft-lbs plus depending on supporting parts, and torque builds horsepower. Don't get scared about using scat or eagle products. These cranks and rods are a lot better than when these companies first appeared. Their quality control has gotten superior. I'm using the scat internally balanced rotating assembly. BBC's like compression and need a good breathing head. I'm using a 4.250 stroke, 6.535 rod and pistons with 1.120 compression height. Deck the block to get 0 deck. You want to get around 10.5:1 compression to run 92 octane pump gas. I've had sbc's and once you get finished with your 496 and feel the power you'll never got back to a small block. If you source the parts right you'll get the short block done under 2k and you can source out for some good flowing aluminum heads. You can get the aluminum 502 crate motor heads relatively cheap around 5-600 dollars until you can upgrade to some AFR's, Dart or Brodix heads. If you want give me a call 775-738-5476 or email me at torqflyte@hotmail.com
Thanks, James Hope this helps
warriorcustoms
02-29-2012, 03:27 PM
I know its not a car But ive drove boats with stock 454 & 496 motors That 496 is meaner hands down
dkcoleman01
03-01-2012, 03:26 PM
Thank guys for your input.... after reading many threads and asking a lot of questions some may have been stupid, but I have made my mind up.... I am going with the 496. Thanks again guys
cambirdracing
03-01-2012, 04:36 PM
We built a 489 for my wifes 71 Camaro. It cost the same as a 462 at the time. Why not go bigger? Glad you made the choice of a 496.
No substitute for cubic inches. :)
30th#654
03-01-2012, 10:28 PM
Im Building a 72 C20 originally equipped 400 BBC (currently sits a 355) id like to put a BBC back where it belongs, think maybe i could i get that same extension
mrdragster1970
03-02-2012, 07:18 AM
Good decision. Like I said, a 496" is a good start, just don't expect some huge difference, like 100-200 HP.
It is definitely a great time to build strokers, and parts are everywhere.
Just becareful you get the best bang for your buck.
I spent a lot of money building a stroker and it ended up making the exact same HP.
The head was too mild for the extra inches.
Good luck.
torqflyte
03-05-2012, 04:05 AM
Hi 30th, you can definitely give me a call also if you'd like. For that matter anyone can call me to chat about any build they have. That C20 would really wake up with a 496. Nowadays with the craze of GM LS engine swaps the 454 is readily available, mine was free, and you can usually bore a mkIV block .100. Building a budget 496 can be done cheaper than an LS, producing the same HP and TQ. The LQ4 and LQ9 LS blocks are only around 25 lbs lighter than the mkIV 454 blocks.
I've been in the drag racing scene since the late 80's. I owned and operated a transmission business and had sponsored many Div 5 racers. I built transmissions mostly for the Stock Eliminator class. 2 of which held national records in ET and MPH; A/SA 64 Plymouth Savoy (fastest automatic transmission stocker in the world) and then a G/SA 73 Duster. Since my divorce in 2005 and losing everything, I now live in NV and remarried. I'm slowly getting back.
I'm currently building a 77 Camaro, AFR headed 505 BBC with a 4L60 (700r4). It should be one bad ass muscle car when completed. Like I said, BBC’s need compression and a good flowing head. You want to achieve a net quench area of .032-.037. In order to get CR 10:1 and above you’ll need to use a substantial dome, which the flame propagation is hindered. The piston domes should be relieved so the flame front can go over the piston dome.
396375
03-09-2012, 10:00 PM
Is the trans going to be a 4L60E or a 700R4?
JWStevens
03-09-2012, 10:32 PM
I've been running 454's since 1999 and I have yet to figure out how you can build a 496 for the same price? If you have a good core and some decent iron oval ports you can run in the 10's on motor with a 3400lb car. Flat tappet cam, Stock rods, crank, and old OEM LS series piston. I would def rather have a bigger motor but most of the guys on here are talking about street cars so I don't see where they need aftermarket cranks and rods for a 10:1 BBC? Not being a D*ck but it def seems to be a trend on here. I've got about 4 of these motors and one is getting a 6-71 put on it with stock heads, stock rods and cast crank. These things aren't 350's guys. There are guys going way faster than my junk with stock stuff.
mrdragster1970
03-09-2012, 11:08 PM
Some people will not use stock or used cranks, rods, pistons etc.
So if starting from scratch, sometimes you can build a 496" for the same price as a 454".
Again, if you have the head to take advantage of the extra size, you will see a decent power increase.
If not, you have the base for a new head when you can afford it.
My crew chief has ran well into the 9's with stock short blocks.
He kept pretty close to me using all aftermarket stuff, that cost a hell of a lot more,
but he had more experience/ knowledge, I had more money.
So as I learned, and got better stuff, I pulled away.
You definitely can make some decent power with stock parts, but you will hit a level where it stops.
JWStevens
03-09-2012, 11:34 PM
I def agree with you, but IF you have a core its way cheaper to build a 454. I crew for a friend with a pro mod and I've got a couple of sets of pull out rods but I don't need them for a 600 horsepower motor?! I guess that's what people mean when they say people buy lessons when they don't know any better. With these budgets these guys say they want to spend sometimes the aftermarket stuff isn't doable and everybody scares them to death saying they won't stay together with stock stuff.
30th#654
03-10-2012, 11:40 AM
ok so for the original question, 468/496 ?, the popular vote goes to 496 correct? with a
side note that a stock 454 with some sweet heads can produce the same power level ?
JWStevens
03-10-2012, 11:59 AM
Def 496 if you've got the money.
mrdragster1970
03-10-2012, 08:52 PM
1st, I have a Pro-Mod, and when I'm done with the rods, I wouldn't put them in anything except a display/paperweight.
Plus they are way too long to even fit a stock block.
2nd, my 468" ran 9.32, I built a stroker with the same heads, and it ran 9.31.
The engine will make the power the head can support.
All you are doing is lower the HP per inch numbers.
3rd, like I said, you can build a reliable race motor with a stock short block if you know what to do.
I won't do it but other do it everyday, 700-800 HP.
Now, for $4000 is it possible to do much other then use all stock & used stuff??
I would be no help there. I can't even get heads for $4000 on the stuff I build.
JWStevens
03-10-2012, 09:16 PM
We pull our rod after 25 passes and yeah I'm silly enough to put them in a 600-700 HP motor even after they've been turned 9800. We use 6.665 rods that will fit in my 10.2 stock block because that's what the pro mod block is. We run blowers so we don't run super huge motors. I was under the impression he was spending 4k on the whole motor. That's tight for all new stuff if you use new heads. I didn't think he just meant 4k for the short block.
torqflyte
03-11-2012, 06:48 PM
So the original post was 468 or 496 daily driver and weekend warrior on a 4000dollar budget. I'm not a Pro Mod racerA 496 on pump 92 octane gas can be achieved within the budget. I've outlined an example at a total of $4165 which doesn't include rocker arms, pushrods, carb, headers and covers. But it's all brand new in the box. If going with the scat 9000 cast steel crank and scat 4340 I-beam rods you're under $4000. Sure you can build a 468 cheaper reusing a lot of the original parts, except the pistons and all the machine work to reuse everything to get around 475-500hp. IMHO, I wouldn't reuse all the the parts like crank, rods, pistons. And this is when the price of a 468 and a 496 is virtually identical. which is my other point. The other point is, what is laid out is only an example. The parts are all brand new except the block and is capable of 500-600hp. I've built 496 BBC's and achieved over 650hp and over 630ftlbs of torque. It idled at 675rpm and ran on 92 octane pump gas on a budget of $7000. The engine is in a nova with 700r4 (I built also), 478 gear 9" ford, has 26,000 on it and runs 9.30's with hoosier 33x14.5R15 slicks. On the street he runs 3.89 gears Mikey thompson street radials 28x13.5R15.
http://www.usaperform.com/scat-rotating-assemblybalancedbc-4250-4310-forged-crank-hbeam-dome-1021-p-1852.html
4.310 bore & 4.250 stroke
496 cid
Scat forged crankshafts
6.385in Scat 4340 forged H-beam rods
850 HP w/ ARP8740 and 1200 HP w/ARP2000 rod bolts
KB Pistons +17cc = 10.2-1
Mahle/SRP forged pistons +18cc Dome = 10.2-1 with 118cc heads
Plasma moly file fit rings
Clevite H series rod & main bearings
Precision Balanced Internally
Use 396/427 unweighted flex plate & harmonic balancer
S496-42355B 496 10.2 Forged KB $1,759.00
S496-42360 496 10.2 Forged Mahle/SRP $1,929.00
http://www.usaperform.com/block-chevy-aluminum-strike-force-heads-320cc-p-836.html
SF320 Bare, pr 320 115 2.250/1.880 $987.50
SF320-3050 Assem, pr 320 115 2.250/1.880 1.510D Steel Hydraulic $1,329.50
SF320-3450 Assem, pr 320 115 2.250/1.880 1.460D Steel Hyd Roller $1,349.50
SF320-3450 Assem, pr 320 115 2.250/1.880 1.460D Steel Solid, flat $1,349.50
SF320-3870 Assem, pr 320 115 2.250/1.880 1.625D Tit Solid Roller $1,549.50
http://www.usaperform.com/install-flat-lift-machined-retainer-lock-timing-p-1696.html $235
http://www.summitracing.com/parts/CCA-11-250-3/ Comp Cams CB XE284H-10 $135
http://www.summitracing.com/parts/PFS-53031/ Professional Products Single plane intake $255
Clean and Machine block $450
JWStevens
03-11-2012, 07:34 PM
For him it would def be better to build a 496 because he doesn't have anything. I never reuse pistons but good rod bolts go a long way. I still run the first 468 I ever bought (in 1999) to this day and I'm sure its very close to 600 if not more and it all stock in the short block except the rod bolts and I don't know any secrets at all. It even has stock little oval ports on it. That stuff is just strong. I think 500HP would be very simple to get out of a 454 but that's just me. The only crank I have ever broken was a small block new aftermarket eagle POS with a blower on it and it was because of the blower. I wish him luck but he's gonna have to spend it well to come in under 4K. This topic has made me interested to see what EXACTLY it would cost to build a 500HP pump gas 454 and do something I never waste money on and dyno it for proof. I think ill start rounding up JUNK parts and see what can be done for about 2500. That sound like a good budget for 500HP.
dkcoleman01
06-16-2012, 09:22 PM
Thanks for all the input you guys gave. This is just an update on what I have done so far with my 496 build.
Block I already had
Heads already had casting number 3856206
Machine work – 650$
Hyd. Roller Camshaft kit – 1000$ (comp cams)
http://www.compperformancegroupstores.com/store/merchant.mvc?Screen=PROD&Store_Code=CC&Product_Code=K11-413-8&Category_Code=MARKIVCAMHRXE
Short Block Assy. - 1175$ (From Whites Performance)
http://www.whiteperformance.com/RotatingAssemblies.htm
Intake – 200$ (Ebay)
Misc. gaskets, water pump, oil pump etc… - 300$
Total WITH my heads I already have 3325$
Total with better flowing aftermarket aluminum heads – est. 2500$ which would put me at around 5825$
I was thinking about putting the 206 heads on there to bump up the comp ratio but would like to go with AFR heads.
So now I debating if I should go with the 206 heads I already have or just save up for some better flowing heads….
warriorcustoms
06-19-2012, 01:17 PM
Ran a 496 in a boat once it was a ton of fun :) Always build the biggest you can afford Theres No Replacement For Displacement
Bar50
06-19-2012, 08:31 PM
Just don't under estimate the factory, full size oval port heads, like the -781 or -049. Either with 2.19 & 1.88 or 2.25 & 1.88 valves will flow like gang busters. One can find pretty good deals on the used, take off 454 Mercruiser/Mag heads from guys upgrading power boats. They are GM square ports, -088 or -188 casting numbers....
MackTruck49
07-05-2012, 12:13 AM
Hey guys...the chevelle i just got has a 468 in it, havnt got it running yet its been sitting for 4 years after being built and mated to a tranny and dropped in the car and never finished... it has scat internals and I literally got the car today but the guy who did it has been racing and building for years and it dyno's at 706hp...it has 12.5:1 compression with steel heads...and they were building it to put nitrous to it. I need to obviously look further into this,because he could just be feeding me a line of BS because im still kinda learning...my uncle has an engine dyno, so maybe ill be running it on that to verify. He also says it needs 1100 cfm to supply it what it needs, so ill be looking into this. Can I run this with 93 octane? seems like to much compression for that...
dkcoleman01
07-05-2012, 10:48 AM
I was always told to keep something on pump gas(93) the comp ratio needs to be under 11:1. anything over 11:1 you get into race fuel. Now that is what was told to me for a 12:5:1 ratio I would think no you can't run 93 octane.
Bar50
07-06-2012, 01:33 PM
You can 'fade' some of the octane requirement with aluminum heads. Otherwise, you are right on about pump gas, I would consider 10.5 the edge for pump gas with iron heads.
