had car on lift today, not good...
so i had the car out for the first time since i brought it home, got it all inspected passed perfectly here in NY with the SD tune and no o2 sensors hooked up, i was very suprised but very happy as well. so here is the bad part. whoever did the y pipe in this car did a really shittty job. its at a bad angle doesnt go straight and is hitting the driveshaft. also, the driver side of the y pipe is completely flat on top? in the pics you can see where it was modified to work with the rest of the y pipe. also ive never noticed on other fbodys but my headers are at much different angles then ive seen? i am very worried about the y pipe touching the DS especially since its starting to scratch it up.
first pic that shows y pipe touching DS and the wear mark on driveshaft
here is the next pic that shows how bad the angle if y pipe is
and here is the last pic that shows how uneven the headers are(idk if this is how they all are but just looks very odd)
all info would be great, i really love the corsa exhaust and dont want to take it off but if i have to i was going to sell it and do a true dual setup
yeah having two diferent looking headers is normal for our cars due to the odd fitment clearences, however as 01fastws6 said, your y pipe was done by an idiot, depending on your money situation you can leave it or replace it, i would replace it. clamps on the headers' colletors, wtf i have never seen that, it should be a three bolt flange with a gasket in between.
alright good im glad to know the headers are supposed to be at those angles one less thing to worry about. now as far as the y pipe yes it was an absolute horrible job done and i am pretty pissed off(not previous owners fault he bought the car the same way) but yes i want to do something with it. now the only reason i can see them doing the y pipe like this is because it looks like it was going to hit the tunnel brace. if that was out of the way it could have gone together straight and not have this crazy angle on it. as far as it hitting the DS i am very mad about that as well, that cannot be good. can i removed this tunnel brace withouth having any issues? if i can i will just cut the piping and weld a new one in myself. all probs solved.
Thats even worst, the previous owner before last was either an idiot or had someone who didnt know what they were doing on the installation. I have never heard of any aftermarket exhuast not clear the stock tunnel brace. I would remove it to make it easier to work on but I would put it back on. If the tunnel brace is in the way, I would have someone do some fab work around it.
The Scammer Hammer
If they remove them on every install then it wont be a problem to just remove it completely. Never had that problem with my Hookers or know anyone else that did for that matter..............
I had to remove my tunnel brace to install my corsa with the ARH headers and ORY on my 02. Wouldn't clear otherwise. Glad to see some other people had to do it with other systems too.
that pass side o2 needs to be replaced also... why in the world they have it running off of one, you're guess is as good as mine unless it's on a speed density tune lol.
re-read op.. whoops... but yeah someone made the suggestion of removing the tunnel brace, and that does wonders for getting some more clearance.
The Scammer Hammer
It is a SD tune. But while we're being nit-picky, I spy a FRAM oil filter.....LOL
Op, seriously, figure out whose brand headers you have and either get that Y, get a TSP stainless Y (since you live in NY) and be done with it.
I'd be ashamed of myself as a welder if I did that.
holy **** thats bad. I can tell you mike that with the power your making and seeing as that shitty stock driveshaft is already grooved, thats a weak link and it WILL snap. When, I dont know but when it does, without a driveshaft safety loop or anything it will be bad.
spend the money and get a tsp ory, a new driveshaft and a spohn torque arm with a safety loop.
