2002 camaro ss
2002 camaro ss
Year: 2002
Make: Chevrolet
Model: Camaro
Price: $9000
Mileage: 115000
Private or Dealer Listing: Private Listing
Location (State): IN
Color: Silver
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
car has a whole new rebuilt top end including, valves, valve seals, patriot 650 dual valve springs and retainers, comp hardened purshrods, ls7 lifters, and comp custom grind cam (226/236 526/526 110 LSA.) (done when engine was put in)
new GM timing chain and melling oil pump (done when engine was put in)
all new gaskets and seals (done when engine was out in)
new ls7 clutch and flywheel with slave cylinder (done when engine was put in)
plugs and wires
hooker longtubes
off road Y pipe with rear oxygen sensors tuned out so no check engine light
Weld in magnaflow muffler so whole exhaust is still stock stainless
Cutout before muffler which can be manually capped off
Vogtland lowering springs (still have stock ones in garage)
All 4 Koni adjustable struts
Global west front upper control arms
SLP intake lid
SLP sub frame braces
Motive 4.10 gears (noisy on deceleration)
This car has a clean and clear title and i still have the original window sticker and some paperwork from its past. It was recently dyne tuned by straightline performance and made 374 wheel horsepower and they reported no problems.
Please text/call (219)241-eight three zero six i prefer text because between school and work i don't have much time to answer my calls.
