bad pcm symptoms??
bad pcm symptoms??
How likely is my pcm bad with a P0740 tcc cuircut problem and an injector fault code<I forget which code> I've heard could be likely for both and I've replaced tcc selenoid and injectors with neither helping. Just want to know if these are pretty common bad pcm symptoms.this is a 2000 pcm if it matters.
