Nitrous Oxide - Nitrous accessory ports
coolmanvette75
02-28-2012, 10:39 AM
Hey guys quick question. I need at run a gauge, blowdown tube, and pressure sensor for the heater on my set-up. The problem is that I only have 1 accessory port on my NOS hi-flow bottle valve. Any suggestions on what I can do?
NitrousExpress
02-28-2012, 11:08 AM
Well we have a couple of manifolds that you could use. What size is your feed line?
coolmanvette75
02-28-2012, 11:42 AM
-4an.
NitrousExpress
02-28-2012, 02:56 PM
Well we have this manifold that would work great for you.
http://fourm.nitrousexpress.com/product-details.php?id=227
This would allow you to run who more accessories after the valve.
coolmanvette75
02-28-2012, 09:05 PM
So you just screw this onto the bottle nut?
Nitro Dave's Nitrous Outlet
02-28-2012, 11:08 PM
This is what you will need.
http://www.nitrousoutlet.com/catalog/product.asp?category=27§ion=98&group=643&product=3786
Our manifold fitting is a dual accessory port and it swivels. With the style bottle valve you have this will be very useful in order for you to be able to place the fittings in the stoping position you need.
This will screw onto your bottle nut. Then the main feed line will screw onto the oposite end. The center of the fitting will have two 1/8 npt holes. In these holes you can put your gauge and pressure switch.
The blow down tube will hook to the NHRA fitting on the bottle valve. If your bottle has this fitting it will have a 8 an thread off the valve. If it does not you will need to purchase the NHRA valve. Can you post a picture of your bottle set up?
Dave
NitrousExpress
02-29-2012, 05:13 PM
Yes i would screw on to the bottle valve. If you need one that swivels we do also offer on that swivels.
http://fourm.nitrousexpress.com/product-details.php?id=1514
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
