Tools & Fabrication - Looking
View Full Version : Looking
oxblood!z28
02-28-2012, 01:30 PM
Looking to buy a Comp Cams Degree wheel Kit, but there seems to be two kinds one of them being COMP Cams 4934 - COMP Cams Cam Degree Kit
and the other COMP Cams 4796 - COMP Cams Cam Degree Kit, they would probably do the same thing just the same. But I was wondering if you guys had any experience using one of these and if not what would you recommed?
oxblood!z28
02-28-2012, 05:18 PM
anybody
mebuildit
02-29-2012, 06:51 AM
If you are looking for a degree wheel, look for the largest one you can find. Reson being is that a larger degree wheel is more accurate than a smaller one.
I think that Erson has them, might check them out.
Old Geezer
02-29-2012, 07:48 AM
Powerhouse has the large wheel, and a lot of other items you may need....
[AIRC, Powerhouse is now owned by Comp..]
Old Geezer
02-29-2012, 07:50 AM
http://www.powerhouseproducts.com/ph/catalogsearch/result/?q=degree+wheels&order=relevance
oxblood!z28
02-29-2012, 02:08 PM
thanks guys looking for small wheel motor is in the car. would you say its fairly easy degreeing a cam on these motors?
wav3form
02-29-2012, 04:51 PM
I know not everybody degrees a cam but is it recommended? I assume it's just to verify that the cam grind is accurate according to the cam card? Couldn't you just use a dial indicator and see where piston 1 registers when at TDC?
Mike52
02-29-2012, 09:00 PM
It's a little more involved than your description. :D
Oxblood, Comp Cams has a new degree wheel kit #4942 (http://www.compperformancegroupstores.com/store/merchant.mvc?Screen=PROD&Store_Code=CC&Product_Code=4942&Category_Code=) designed specifically for the LS engines. It's more than just a degree wheel, it includes a dial indicator, LS specific threaded stands and a piston stop. Summit has them in stock.
oxblood!z28
03-01-2012, 11:00 AM
I thought they made one specific for LSmotors the link that Old Geezer left reassured me. so I called summit and they gave me a price. I'm debating on getting the piston stop that goes through the spark plug port. The only reason I'm ify about it is because I think I'm going to need to replace the head gaskets if I do. Trying to save as some cash if I can. Out of the two piston stops offered which would be more accurate?
