Water Pump & Alternator install/write up needed.
Any links would be appreciated. And if you've installed any of these give me what to look out for and how easy or hard it was.
Water pump is very easy, just messy. Try this as well, its for an EWP but still basically the same nonetheless.
http://www.ls1howto.com/index.php?article=26
I just did a waterpump this past weekend... I'm an idiot and got through it just fine so I'm sure anyone can do it. Make sure the t-stat fits if you got a new pump (GM) since they seem to have changed the housing. I had to grind mine. Look for my username for some pictures if you run into this.
johnny5
johnny5
