10 Second Club - am i capable of 10's
View Full Version : am i capable of 10's
jt_2002_ta
02-28-2012, 02:37 PM
01 ta, built a4,4000 stall,full bolt ons,125 shot, lca's w/relocation brackets,Dr's. Or will I need more suspension work?
jt_2002_ta
02-29-2012, 08:24 AM
Planning on a non adj torque arm, lakewood 50/50 in back, qa1 r in front, a good 3 point subframe con, and a 28" tall slick, with this and the above would high 10's be possible?
dodson55
03-16-2012, 09:58 AM
i think you will be closer to mid 11s
whitess1
03-19-2012, 11:58 PM
had a 98 z hardtop no weight taken out of car. bolt ons small cam stock 241 heads wieand 85mm intake 125 shot. stock shocks 1.5" lowering springs lca's fully adjustable chassis mount torque arm. a4 yank 4000ss 9" 3.70 gears 26" drag radials. best time 11.21 @ 119 mph 1.48 60'. Definatly suggest adjustable torque arm
Tan327
03-20-2012, 05:01 PM
It's possible. Best thing to do is hit the track and see how the stock suspension does. I think many make the mistake of buying every suspension part in the book when a lot is useless for drag racing. I'm not saying suspension isn't important, just feel it's a "buy what you need" type deal.
