3channel to 4 channel
Old 02-29-2012, 02:36 PM
hodge9386's Avatar
Default 3channel to 4 channel
iv looked around and seen were you can change a 4 channel rear to a 3 channel, but has anybody changed the car from a 3 channel to a 4 channel? if you put a 4 channel rear in a 3 channel chassis what would you need to do to change it to a 4 channel? i know a 3 channel has one line that comes back for the abs but could you put a "t" fitting there and run them out to the reluctor rings on the end of the axles?
Old 03-01-2012, 09:32 AM
hodge9386's Avatar
anybody?
Old 03-01-2012, 01:52 PM
gi8e7oi825's Avatar
Originally Posted by ShowNoMercy
Off the top of my head, you will need...
-4 Chan ABS unit
-Remove old rear brake line, replace with two new ones
-4 chan axles with reluctor rings
-ABS wheel sensors and corresponding harness.
The wiring in the new ABS block with new sensors would be a royal pain in the *** IMO.
http://www.ls1lt1.com/forum/rear-end...4-channel.html
I thought about doing it once...
Old 03-04-2012, 10:37 PM
DarkJuggalo's Avatar
nvm, thought u meant the rear not the whole car lol sry
