gt91 408 cnc ls3 heads hows this cam look
Old 02-29-2012, 05:47 PM
1bigcam's Avatar
Default gt91 408 cnc ls3 heads hows this cam look
231/235. 617/.621. On a 114
Iam looking for a agressive cam and this is what tsp came up with
408 ci , cnc ls3 heads , ported ls3 intake
Th400 trans with 3400 stall 9" ford 3.23 gears
Turbo is a gt91 t6 1.08 exhaust 5" down pipe
Old 03-01-2012, 08:52 AM
turbo iroc's Avatar
I wouldn't say its aggressive ...I'm running a 230 238 on 114 575 585 on a 402 l92 heads 9.3cr t6 88mm 1.08a/r it has 14 in vac at idle and pulls at 1100 rpm in fifth gear.
Old 03-01-2012, 08:53 AM
turbo iroc's Avatar
3.42 gear tko500 five speed.
Old 03-01-2012, 09:23 AM
westtexasbuff's Avatar
That looks more like a mild cam. I'm running a 231/247 .617/.624 113. 377ci, LSA heads, twin 67s, 3" downpipes.
Old 03-01-2012, 10:45 AM
Fbodyjunkie06's Avatar
I would say something like this is aggressive...
237/251 114 lsa or 235/247 115 lsa it really comes down to the valve events though and overlap.
Old 03-01-2012, 11:01 AM
corpserodeo666's Avatar
Mine is a 230/240 .598/.608 115 LSA +3 on a 408 and an s91 turbo.
Old 03-02-2012, 11:05 AM
V-10 Killer's Avatar
Just for point of comparison, I did some online chat with Comp Cams yesterday speccing a cam for a LS2 402/GT91 turbo build I'm going to start, and they came up with a 243/243 .624/.624 115+2 LSA cam. I specced it a bit more towards drag car than street car, but just something for you to compare against
Old 03-02-2012, 11:56 AM
LS1Tech Sponsor
hellbents10's Avatar
I would say its pretty mild and would drive like a caddy on the street. You will be limited by the heads lifting before the cam hurts you.
Old 03-02-2012, 12:48 PM
1bigcam's Avatar
At what point do you think the heads will lift on this motor ?
Old 03-02-2012, 03:15 PM
LS1Tech Sponsor
About 950-1000hp with those castings. Even with 1/2" studs you will be fighting with those heads. If you want to ring out that 91 a good cylinder head will be needed. We have good luck with the TFS heads to 1500 with 1/2" studs.
Old 03-02-2012, 03:41 PM
1bigcam's Avatar
Iam looking to make 850whp so i hope this will hold up, what has to be done to run 1/2 studs
Old 03-02-2012, 03:43 PM
LS1Tech Sponsor
The engine block needs to be drilled and tapped for them and then you might need to clean up the head bolt holes a touch.
Old 03-02-2012, 03:55 PM
1bigcam's Avatar
Ok thanks for the help
Old 03-02-2012, 04:08 PM
LS1Tech Sponsor
Slowhawk's Avatar
For LS3 heads that Cam will be fairly aggressive. Stockish cathedrial port heads -no.
850rwhp would not be an issue. Only need 14-15lbs of boost to make that.
Old 03-02-2012, 11:03 PM
I've seen the work you guys do with LS3's, can you elaborate on this some more Slowhawk?
I'd like to pick your brain on LS3 cam selection.
Old 05-04-2013, 09:11 PM
z0vette's Avatar
Am in the same boat.. Same motor, same body but smaller turbo (presicion GT42 AR 0.121
Quick Reply: gt91 408 cnc ls3 heads hows this cam look
