gto 243s valve seal????
Old 02-29-2012, 07:07 PM
86 g-body's Avatar
Default gto 243s valve seal????
my 243 out a gto with a 6 liter are off to get milled and valve job.I was wanting to order new valve seals but dont know witch ones it takes top hats or the cups..anyone know the seals i need???
Old 02-29-2012, 07:09 PM
NVR_SPDS's Avatar
Im running the cups on my 799s. They are the ones that came with my PRC springs. It may depend on what springs you are running, since the top hats were the ones that came off.
Old 02-29-2012, 07:23 PM
sfc rick's Avatar
Isn't the Machine shop building the heads? Seems like I would let them install them.
Old 02-29-2012, 07:45 PM
86 g-body's Avatar
i buy...... they install
Old 02-29-2012, 07:47 PM
86 g-body's Avatar
im running the yellow springs that came with the heads
Old 02-29-2012, 07:57 PM
ZeeOSix's Avatar
I'd run the GM guide seals if you're running the OEM springs (or any beehive spring).
Quick Reply: gto 243s valve seal????
