Dyno Guesses & Bench Racing Forum - would high 10's be possible
View Full Version : would high 10's be possible
jt_2002_ta
02-29-2012, 08:01 PM
just currious if tens would be possible. mods in sig plus lca reloc brackets, non adj torque arm,panhard bar,lakewood 50/50 out back,qa1 r's w/275lb spring, and mt dr's. im thinking if i can set the suspension up that i could flirt with high tens, what do you guys think?
MonmouthCtyLS7
03-01-2012, 07:43 AM
A lot of factors...only one way to find out...id be more concerned w/ your 10 bolt.
odarabla
03-01-2012, 09:42 AM
So your a bolt on car with 125shot of spray? I don't know man.. Ima say no. But that is just an oppinion..
My last motor was a H/C/I stock bottom end motor and I went a best of 10.90@123mph full weight and stock suspension with a 1.46 60ft.. What is your best mph so far?
c0ncEpT
03-01-2012, 09:58 AM
Get that car into the 11's on motor and there shouldn't be any reason it doesn't go 10.99 on a 125 hit.
Gonna have to get it working in the 1st 60' also. 1.4x minimum
