General LSX Automobile Discussion - Help Weird engine noise
ryankeene
02-29-2012, 10:05 PM
So i just started up the camaro and the engine at idle is making a slight knocking sound . its coming from the left side facing the car . sounds like its under the valve cover. any idea what this could be?
could it be the lifters tapping?
BigBirdLS1
03-01-2012, 10:37 AM
More details please. Mileage amount you drive it mods etc. Any info you give us will help. Could be piston slap all the way up to spun bearing.
ryankeene
03-01-2012, 10:57 AM
Mods in sig then titanium lifters and pushrods comp beehive spring . Daily driver get on it every now and then
BigBirdLS1
03-01-2012, 01:39 PM
Sorry I can't see the signature on my phone. Judging by the mods you listed the valvetrain is the likely culprit. Does it change sound with rpm? Try taking a long screw driver and touch it to your valve cover then put your ear to it. That may give you an idea of what cylinder it's on.
ryankeene
03-02-2012, 02:08 PM
Texas tr228r, FAST intake/TB, Lid, SLP L.T's and ORY, elec cut out, Gmmag, SPHON upper/lower A-arms Torque arm, sub frame connectors, Hurst, Ls7 clutch, Ls2 flywheel, Drilled/ slotted rotors, ceramic brakes, 4:10's, Nitto extreme N555 rear 315 front 275.
409 rwhp
374 rwt
yeah it the amount of taps per second increases with rpms increasing. do i need to take it to a shop or is there something i can try to do
could it be a header leak ?
BigBirdLS1
03-03-2012, 11:34 PM
It could be an exhaust leak. Its just hard to say without a video or hearing it in person. Try this you said its on the passenger side right? Crank the car up and pull off one spark plug wire at a time. When the tapping you hear goes away there you will know what cylinder its on. If the tapping doesn't go away but only changes tone then its most likely exhaust leak.
ryankeene
03-07-2012, 04:43 PM
Thanks ill try that
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
