Sponsored by: DashLynx
What paint to paint my FAST intake
Old 03-01-2012, 05:30 AM
gotjuice?'s Avatar
Default What paint to paint my FAST intake
What do you guys use to paint your FAST intake??
Old 03-01-2012, 06:35 AM
'02 WS6's Avatar
I used a couple base coats of adhesion promoter, and then topped off with gloss black spray for plastics, composites, etc. Got it all at Auto Zone.
Old 03-01-2012, 07:15 AM
justin hover's Avatar
budget wise duplicolor works fine. 2 light coats adhesion promoter, 2-3 coats filler primer(sandable primer is optional) depending on how well you sanded it. 3-5 coats paint of your choice, I did 7 coats of clear coat to really give it that powder coated look. All rattle can. The trick is prep work, don't skimp out on sanding. I went 120,220,400,600,then 1000 grit, smooth as can be.
Old 03-01-2012, 10:21 PM
gotjuice?'s Avatar
I'm looking for the factory FAST look,do I still have to sand it smooth??
Old 03-01-2012, 10:32 PM
hodge9386's Avatar
just clean he **** out of it, adhesion promoter, self etching primer, krylon fusion from wall mart. works great.
Old 03-02-2012, 12:33 AM
sokr915's Avatar
For my LS6 I gave it a nice bath then hit it with 400 then 800 then 1000grit sand paper then some adhesive promotor then a high build primer then few coats of duplicolor and then duplicolor clear. It came out great.
Old 03-02-2012, 05:49 AM
Whats wrong with the factory look it has right now?
I'd reccomend sanding it, It will give you that smooth gloss look.
Old 03-02-2012, 09:47 AM
Cape T/A's Avatar
then why paint it?
Old 03-02-2012, 10:03 AM
hodge9386's Avatar
didnt sand this one and it looks great, i guess you could call it the factory fast look
Old 03-02-2012, 10:31 AM
Cape T/A's Avatar
That looks sharp!!!!!!!!!!!!!!!!!!
Old 03-02-2012, 10:35 AM
firemech21's Avatar
I painted my intake with the VHT wrinkle finish and I think it gives a close look to the casting marks.
Quick Reply: What paint to paint my FAST intake
