Set of Rocker arms and 99-00 LS1 heads
Category: Engine - Intake/Fuel
Price: $0
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): MD
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Set of rockers off same engine with rocker stands and bolts all bearings seemed there and good $50 plus shipping.
I'm gonna look through the garage and see if there is anything else I might not need. Thanks.
Needed to add this because I don't want to mislead somebody and feel I need to be honest. A user asked me to get some pics to him and as I was taking a real good look at the heads this evening I saw some slight rusting on some the stock valve springs. I presume it was from the humidity in the garage and from sitting for all these years. Thought I had them oiled down well enough before I put them in the bags and on the shelf, guess not. What I saw, I rubbed with my thumb and it came right off (surface rust), but I don't know that would be the case with every spring on both heads being I didn't look over the springs much more once I found that. So the heads you should consider as rebuildable castings. Yes, about 98% of it is G2G, but I can't say it is 100% based off what I just saw.
I looked real good at the rockers and they are just fine.
As far as I know the mileage is correct. I purchased it from a GM garage that just had it laying in a corner in the shipping crate all these years a year or two ago to use for a build up for my little truck. Like I said came off a warranty motor which was pulled for a piston slap issue. Bearings and all were super clean, no reason to suspect the mileage I was told was anything different. Pictures of the rockers
Picture of the main bearings from that motor so you get an idea of the wear on the motor
Also, here is a pic of the #1 piston when I got the motor apart. You can see where it was rocking in the bore.
Let me know. Thanks.
