Gen 5 Camaro Racing Tech, Results - What should it run? 418 stroker
View Full Version : What should it run? 418 stroker
QUEST4-10S
03-01-2012, 04:31 PM
I built a 418 stroker, Lloyd Elliot portwork to the heads, cam is a Comp .595/.608 lift, 232/240 duration on a 113 lobe separation. Circle D 3000 stall. What do you guys figure it will run down a 1/4 mile? Assume these times with drag radials.
sweetC5
03-01-2012, 07:30 PM
In a 5th gen, what kinda power did the motor make?
QUEST4-10S
03-01-2012, 09:34 PM
Never got dyno readings, just a good tune. It runs like a raped ape, just we haven't run it on dr's. The few passes we got at a track, the timing system was not working and we fried the tranny. I am guessing with drag radials mid-low 11's based on what I find from other builds. Just not sure if I will find out, my customer doesn't look too enthusiastic about heading to the track again after frying the tranny, LOL. That night we ran against a boss 302 that runs 11.7's, it took us half track but the Camaro caught up in the end. That's why I figure with traction it should perform well.
sweetC5
03-02-2012, 08:01 AM
I would say low 11s with DR's, this would be on 20s right. With a drag wheel and tires setup I would say 10s pretty easy. The big wheels and stiff short sidewall drag radails are still going to be a crutch. But from what I have seen I would guess low 11s.
QUEST4-10S
03-02-2012, 08:27 AM
10's hmm... now i got to convince to "invest" in the Bogart setup!!
Rhino79
03-19-2012, 02:42 PM
A purpose built setup like that should be in the 10s. People are breaking into 11s with just bolt ons.
SREETRACEGUY
03-20-2012, 01:34 AM
10s easy
Tekhombre
03-22-2012, 01:36 AM
In the C6? 10s easy. :nod:
LSHUNT
03-22-2012, 08:33 PM
What CR are you running with that stroker? I think real low 11s is realistic.. with full bolt ons and suspension work done you should get into the 10s
Edit: oops i just realized you're in a vette not a camaro, i think you're in the wrong forum lol.. and 10s real easy
QUEST4-10S
04-10-2012, 05:21 PM
Oops, I just realized I didn't state it was a 2010 Camaro. Nevermind the cars listed, those are my personal vehicles, the Camaro belongs to a customer. We are going to give it a blast on 18 inch drag radials and see what it can do. On it's maiden voyage the track timing system was not working and we were on stock tires. We gave a few shake down runs and raced it against a Boss 302 with headers/tune and slicks, which runs mid 11's. The Boss took it half track and at about half track the SS began catching up quick to almost tie at the finish line. So my guess is with traction, it should do easy low 11's. By the way the tranny got fried two days after that visit to the track. Tranny is built, just waiting on retuning, ( trans does some wierd flare up between 3-4 shift ). I will post a times once we get it done. Thanks for the input.
DietCoke
04-10-2012, 08:39 PM
A mild stroker should run low 11s pretty consistantly in a 10' camaro
holley505
05-16-2012, 09:49 AM
I have a carbed 418 with 205 AFR mongoose heads. 240/246 608/612 112 lsa. 3500 stall 3.36 gear in a C3
Still don't have high gear (3rd) th400
1.62 60ft
6.9 1/8th @100mph
11.002 1/4 @ 118 (remember no 3rd have to let off)
Cars weighs 3050lbs w/o driver
3270 with me
holley505
05-16-2012, 10:32 AM
Once my 3rd at WOT is fixed I should go 10.7 around low 120s
