What is it Worth? - 2000 ta
View Full Version : 2000 ta
Striker289
03-01-2012, 06:50 PM
2000 TA, Red, T-Top, 106k miles
Stock Long Block
ls6 Intake
Custom 3.5" CAI
!AIR
!EGR
!Cats
Jet Hot Headers
Custom True Duals Dumped before the Axle(floor is boxed under rear seats to pull the mufflers up)
Eibach Pro Springs
KYB AGX Struts and Shocks
Performabuilt Stage 3 4l60e(about 6k miles, no passes)
4000 Stall Spec'ed by Performabuilt for a stockish Motor(about 6k miles, no passes)
Under Drive Pulley
Trans Cooler with Fan
Poly Motor mounts
Poly Trans mount
UMI Trans Cross Member With Torque Arm Mount
UMI Torque Arm
UMI Panhard Bar
Lower Control arms with Fresh Poly Bushings
Lower Control Arm Relocators
Richmond 3.73 rear gears with Eaton POSI(I believe)
Diff Cover
17" Black c6 ZO6 wheels with red stripe(OE Wheels)
Smoked Tails
HID Low Beams
HID Fog Lights
I'm Sure I Forgot some stuff lol. Just wondering what its worth, I'm on the fence about cutting it up to be a drag car or selling it so someone else can enjoy the car.
Striker289
03-03-2012, 10:27 PM
It also has 3 point sub frame connectors.
Striker289
03-06-2012, 05:09 PM
Bump!!!!!
