Conversions & Hybrids - Do you think cam is to big?
Builtz71
03-01-2012, 11:22 PM
I'm in the process of putting my lq4 into my fox body mustang..it's in my 99 lifted z71 right now..question is,it has a comp cam 235/243@112 in it.do you think this cam would perform well in the car,with a t-56?..a little idle vid of the truck!
http://www.youtube.com/watch?v=eJPjlGPZsyk&feature=youtube_gdata_player
LS1-450
03-02-2012, 05:09 AM
Yup...will work well.
Not too big
bczee
03-02-2012, 09:18 AM
If its in your truck right now. .and going into a car.. your going from a 5500+ lbs truck to about a 3000 lbs car.. with a good gearing and a Manual trans.. you shouldn't have any problem.. just get it retuned.
Builtz71
03-03-2012, 03:06 PM
Cool thanks guys...hopefully it'll run pretty good
Rick Speed
03-03-2012, 04:15 PM
It's smaller then the cam I'm running in my Trans Am with T56 so Yeah it'll run good
GarrettM
03-03-2012, 09:11 PM
Smaller than mine, you will be fine, just make sure you choose wisely on your tuner and get it done right. It pays many times over.
Builtz71
03-10-2012, 01:13 PM
What do you guys think about the stock truck manifold?..just a rough estimate,what kinda times you think I could get with this set
Up?..it's a lq4 0.30 over 10.5:1,with prc stage 2.5 heads..comp ratio should be at 10.8:1.the cam mentioned above..on pump gas,in a full trim 89 gt..thanks for the input guys
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
