s475 choking out?
s475 choking out?
Been messing with my buddies car, its a 70 buick with a 370 iron block and stock 317 heads, t6 s475(standard, no billet wheel or race cover) and a 236 boost cam. 4l80/s60 rear.
It still falls off power at around 6100 on the dyno. I'm not sure if this is norm, I thought she would huff to around 6500. it has a edelbrock truck style intake on it if that helps.
We made 710rwhp tonight on 13lbs, pump gas. It makes peak and don't "fall" off, but more along the lines of flattens out.
Just curious on others s475 experience on peak power. I know all combos are different, just lookin for opinions. It dont nessesarily need to be wound up any tighter, but you never know! I'm also curious on where we will run into running out of turbo if its turned up more
might be interesting to know what it'd do with the filter off. also, i wonder if you are just pushing as much as that s475 can push, you a log of boost pressure across the range.
I made 583 @5200rpm, 10lb's unlocked 4L80, mustang dyno, It spun the tires on the dyno that's why the low rpm.
I'm at the 2:00 mark on the video
http://www.youtube.com/watch?v=iW6X9hDYHY4
